First off, I have an '87 Mustang with a stock 5.0. Speed Density. I do have a nitrous kit installed on the car.
I have a fuel leak on the back side of my motor that appears to be coming from one of the fuel injectors from what I can see. I have a few questions regarding this.
1.) What size injectors are in the car from the factory?
2.) I would like to put bigger injectors in if I have to replace them. I eventually plan on upgrading the car to Mass Air and put better heads and a better intake on it, but not right away. Can I upgrade my fuel injectors now and will it run normal even with the speed density setup it has now? If not, I will just have to put the stock size injectors back in and upgrade them later.
Are there any common leak points other then the injector that I should be looking at? It is kind of a hard area to see and it is wet with fuel all over back there now.
Thanks!
Thanks!
