Fuel Injector Size Selection
So, do you think my setup would benefit from upgrading to 24# injectors? How much hp would you estimate from 65mm throttle body, gt40 heads, and x-cam? I just bought the car and am in process of installing the heads. Maybe I should put some bigger injectors in while I'm at it? Hate to throw away the 19# injectors there now, they're brand new.
DRock9 said:
What happens if you are over 300HP and you still have the stock 19's? Will it damage the engine?
You will run lean at WOT and fail to develop max power. Damage may or may not occur. It depends on if the engine starts to detonate from the lean mixture.
