fuel injectors
  • Thread starter Thread starter jeffs94rag
  • Start date Start date Apr 19, 2007
J
jeffs94rag
  • Apr 19, 2007
I'm rebuilding my top end on a 94 5.0. Just found out fuel injectors are shot. I'm installing a trick flow track heat upper/lower intake a 75 mm throttle body and a 76mm maf. Since I have to buy new injectors should I increase from 19# to a bigger injector. Will be building lower end soon.
Fett
766
  • Apr 19, 2007
Two trains of thought here. The first being, 19# injectors should be fine for your setup, and buying 24# injectors will also require you to buy a 24# MAFS.
However, since you have to spend money on injectors, why not go ahead and buy the ones that you will need as opposed to buying 19s now and 24s later?
That was what I ran into, when I was building my engine I knew I was eventually going to use nitrous and eventually build a stronger motor. So when it came to injectors I found a good deal on 24s and went ahead and got them. With my current setup, I could easily get away with 19s. But I figured it made no sense to spend money on 19s now, only to have to spend more money on 24s in the future. 24s won't hurt you as long as you have a 24# MAFS and tune the car accordingly.
HISSIN50
34
129
Apr 19, 2007
  • Apr 19, 2007
I'm curious, how are the injectors shot?
Also, why the MAF/MAS swap? Your stocker should be good till after you run out of injector IMHO.
I don't mean to downplay the mods - it would just suck to not get as much out of your dollar as you had hoped.
Good luck.
cj99
74
Tonopah,AZ
Apr 20, 2007
  • Apr 20, 2007
i went to 24's and found my bottom end a little stronger but my top end was down on power. i thought i needed bigger ones too, but in the end i went back to 19 and just turned up the fuel pressure.
i have heard 19 lb injectors will support 300 hp.
BigHairyMonkey
411
Houston (Bellaire) TX
Apr 20, 2007
  • Apr 20, 2007
that 75mm TB is beyond overkill
Engine Hiccup at full throttle
  • keel
  • Jun 2, 2026
Fox 5.0 Mustang Tech Jul 30, 2026
keel
  • brandyn200
  • Jun 20, 2026
AeroCoupe
Pro-M 75MM Bullet Flow Sheet - Is this calibrated for 36 # injectors?
  • dan50
  • Jan 11, 2026
  • Digital Self-tuning Forum
Digital Self-tuning Forum Jan 11, 2026
dan50
9
Engine Donor '00 Mountaineer meet '91 Fox
  • 91firecracker
  • May 11, 2026
  • 2 3
Fox 5.0 Mustang Tech May 28, 2026
91firecracker
9
J
Fuel Fuel Pressure Issue
  • justadude07
  • May 12, 2025
Fox 5.0 Mustang Tech May 12, 2025
justadude07
J
