Fuel line EFI
  • Thread starter Thread starter artus70
  • Start date Start date Aug 25, 2004
artus70
72
  • Aug 25, 2004
This may be just a stupid question but I'm new to the EFI world (mostly only worked on Carb. cars) but when I saw my 89 conv. well that was it for me.
Well I'm cleaning it up and noticed the fuel lines are a bit rusted so I was going to replace them with braided line from the tank all the way to the motor which solves the problem and I think looks nice too except a friend said he didn't think I could use braided due to the pressure and that is why it was metal.Not knowing EFI too much I searched summit and jegs but none of the lines say for FI or Not ???? If I can please tell me what size and fittings I will need if not guess I'll have to buy a line bender.
xxxCadillacxxx
82
Ridley Park PA, near Philly
Aug 25, 2004
  • Aug 25, 2004
You can use Braided lines. A couple of my GM friends are pusing 700+ hp at the crank and have rubber/synthetic lines.
QDRHRSE
1,590
Palmdale, CA
Aug 25, 2004
  • Aug 25, 2004
It's kind of a pain unless you buy a whole system. Most guys run -8 or -10 all the way to the regulator and then run a -6 return. Braided line is what all the high dollar fuel systems run. I believe that aluminum lines are an injection no no.
artus70
72
  • Aug 26, 2004
Thanks guys. Yeah I figured it would be a pita but it's gotta be easier then bending line and trying to thread it around....plus braided line handles vibration better. Thanks again!!!
D
Fuel Erratic Fuel Pressure 1985 GT
  • DienstXIV
  • Jan 14, 2026
Fox 5.0 Mustang Tech Jan 16, 2026
AeroCoupe
F
Difference between 83-86 EFI and 87-97 gas tanks?
  • ForeverDrivin
  • Mar 30, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 30, 2026
ForeverDrivin
F
H
Fuel starvation issues, 91 EFI to carb swap. Car dying after 1-3 gallons used. EFI tank, electric fuel pump, bypass regulator. Dual fed carb
  • hassler
  • Oct 11, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 12, 2025
nickyb
D
Fuel 1985 GT Fuel Line Diagram
  • DienstXIV
  • Apr 17, 2025
2K
Fox 5.0 Mustang Tech Jul 12, 2025
DienstXIV
D
J
Fuel Fuel Pressure Issue
  • justadude07
  • May 12, 2025
Fox 5.0 Mustang Tech May 12, 2025
justadude07
J
