One of the precious owners of my car spliced the fuel lines together in an attempt to make a repair. The repair was made where the hard lines turn into soft lines at the engine bay. I cycled the switch and went to check for leaks and found fuel spewing from a small Crack in the rubber line, which was secured with hose clamps. After removing the clamps and peice of rubber hose, I cannot believe it held this long.
So, I figured the best repair is the factory way. This is where I need some help. It looks like the factory uses a barb fitting and nthe hose is simply compressed around the barb. I want to replicate this, and I think the proper line to use is 5/16 nylon????? Is this correct?
It appears you just heat the nylon hose in boiling water, slide it overy the factory barb, and let it cool. Pretty simple. Anyone ever done this? Hopefully someone can confirm fuel line size and type of soft line I need.
Thanks!
Joe
Thanks!
Joe
