Fuel line schrader valve on an '86
NIKwoaC
中國製造
5,525
943
214
Chengdu Province
Does my '86 GT have a schrader valve on the fuel lines/rails? I went to install a fuel pressure gauge yesterday and couldn't find one where I've been told there would be one (behind the alternator or somewhere around that front corner of the engine).
Right now I'm too lazy to pull the upper intake, so I thought I'd ask on here before I really started looking.
Thanks in advance. :SNSign:
there's 2 places it would be. the first and most common is on the hardline that connects to the fuel rail where you've already been told, behind the alternator, kinda by the front of the valve cover. more than likely it'll have a black cap on it, so if you've been looking for a bare schrader valve, that might be why you overlooked it. the second place i've seen one is on the plate the fpr bolts to. i've only seen a schrader valve at the second spot twice though, once being on my current car (fuel rail looks to be factory aside from that schrader valve. the fuel rail came with my cobra intake, my factory rails did NOT have a schrader valve in this location) and once on a random car at a shop.
my 86 gt has the valve literally about half an inch from the pressure reg. just find your pressure regulator it should be right next to it. probably has a little black cap on. it Its on the fuel rail passenger side very close to the firewall.
