Fuel line Tool
  • Thread starter Thread starter gungfusemaj
  • Start date Start date Dec 27, 2003
gungfusemaj
211
Bradenton Fl
Dec 27, 2003
  • Dec 27, 2003
What tool is needed to seperate my lines and where can I go to get it.
5.0Droptop
...all those nights we shared, and you're a dude??
Special Agent Mukity-Muck Whats in Charge Round Here
May 15, 2002
1,785
1,130
233
Indiana
Dec 27, 2003
  • Dec 27, 2003
its the same tool used to remove ac lines most auto parts stores sell them. they are cheap 5.00 or so.
ALMOST STOCK
1,250
41
88
CA.
Dec 27, 2003
  • Dec 27, 2003
You can get them from most Auto parts stores.
gungfusemaj
211
Bradenton Fl
Dec 27, 2003
  • Dec 27, 2003
ALMOST STOCK said:
You can get them from most Auto parts stores.[/QU
Ok can you reuse these lines or do have to replace them with somthing????
ALMOST STOCK
1,250
41
88
CA.
Dec 28, 2003
  • Dec 28, 2003
Yes the line are re-useable.
All your doing is releasing the spring that hold the lines together.
flyinghi3
313
Manorville, LI
Dec 28, 2003
  • Dec 28, 2003
the ones that i have, and are really easy to ues are the 3/8" and 1/2" tube spring lock coupler tool. i dont believe they are the same size as the A/C line, but i could be wrong. also make sure you get the plastic ones. much easyer to use.
GT350R
723
Cleveland
Dec 28, 2003
  • Dec 28, 2003
Yup, called "Banjo clamps".
Dont make the mistake of getting the metal scissor type tool. Costs more and its hard to get it in tight area's and they break too easy. Just get the cheappy blue and red plastic circle shapped ones.
Also, trick to getting them.........
shoot a little WD40 in there. Then get the tool on. Shove the hoses together , then press to the tool in, then pull the hoses apart.
D
Fuel Erratic Fuel Pressure 1985 GT
  • DienstXIV
  • Jan 14, 2026
Fox 5.0 Mustang Tech Jan 16, 2026
AeroCoupe
D
Please help with vacuum lines
  • Dawgs000082
  • May 10, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 10, 2026
Dawgs000082
D
R
Engine Evap and charcoal cannister leak
  • ryan1994stang
  • Mar 14, 2026
Fox 5.0 Mustang Tech Mar 18, 2026
Mcmahst
Time sert kit!!!!
  • Bmanmcbride
  • Jan 12, 2026
1996 - 2004 SN95 Mustang -General/Talk- Jan 14, 2026
LILCBRA
Engine Obstinate Pilot Bearing removal
  • FastDriver
  • Feb 12, 2026
  • 2 3
Fox 5.0 Mustang Tech Feb 22, 2026
manicmechanic007
