I searched on here, found the fittings I would need to run my autometer ultralite fuel pressure gauge, and nothing fit. Dont have the part numbers off hand but I got them from one of jricker's (spelling?) posts.
The fuel pressure gauge fitting is big, and the little npt fitting will not fit, they arent even correct thread size. I figured i probably needed to pull out the fitting in the gauge and put the other one in, but the fitting on the gauge will no come out.
Someone know EXACTLY what I need to hook up my fuel pressure gauge?
can i use a line with the correct size to the gauge on one end and then a different size fitting on the other to mate to my aero. afpr?
I would check both summit and steeda for the line connection you need from the rail. Not sure if you intend to run a braided line from the fitting to your sender or not. If so then you can use this Steeda piece with some 4an braided hose (really just a russel fitting, could probably find it cheaper elsewhere too). Also, NOS fittings will work on the stock fuel rail. Good luck.
