fuel preasure setting?
  • Thread starter Thread starter stang_racer69
  • Start date Start date May 11, 2004
stang_racer69
Giddy Up My Ass!
1,960
Centeral Ohio
May 11, 2004
  • May 11, 2004
What do you guys run on your fuel preasure with simular combos to mine? I set it to 40 with the vacum off for a base and it is around 30 with the vacum on.
Cobra intake
65mm TB
75mm mass air
24.lb injectors
afpr
shorty headers
off road exahust
underdrives
14* timing with spout off
Rick 91GT
Mustang Master
95
99
PA
May 11, 2004
  • May 11, 2004
I start at 38psi (vac off) and go up in 1/2 pound increments
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
May 11, 2004
  • May 11, 2004
Use the SOP meter...
Get one of your buddies to ride along with you. Find a level stretch of road where you can do some testing. Don't choose a speed range that will make you shift gears, the shift quality & speed will affect your results. Use 2nd or 3rd gear and do a run from 2000 RPM to 5800 RPM. Call out the RPM as it increases and have you buddy record it and the elapsed time. If you have one of those cheap digital watches like I do, a stop watch is built in. Start the fuel pressure at 36 PSI, vacuum off and make a run. Turn it up to 37 and make another. Be sure to reconnect the vacuum every time you set the pressure. Keep turning up the pressure and making runs until you notice a drop off in time. If your bud was careful to record the results, you'll have a nice chart to use to find the optimum pressure.
stang_racer69
Giddy Up My Ass!
1,960
Centeral Ohio
May 11, 2004
  • May 11, 2004
I'll have to try that, thanks jrichker
Engine Random hanging idle
  • 706 Saleen
  • Feb 11, 2026
Fox 5.0 Mustang Tech Feb 19, 2026
86HO5.0
D
Fuel pump upgrade
  • dkrupp79
  • Jul 7, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 10, 2025
Scrapla347
C
03 Cobra Low Fuel Pressure
  • CTsnake_03
  • Mar 17, 2026
1996 - 2004 SN95 Mustang -General/Talk- Mar 24, 2026
CTsnake_03
C
Fox Xtremely high fuel consumption
  • PonyGTrider
  • Apr 11, 2026
  • 9 10 11
6K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 9, 2026
PonyGTrider
9
Forced Induction Prepping for supercharger on non-stock build
  • 91fox427
  • Nov 25, 2025
Fox 5.0 Mustang Tech Jan 5, 2026
Qtrhrse23
