Fuel Pressure Gauge
  • Thread starter Thread starter r6bullet
  • Start date Start date Jun 23, 2004
r6bullet
112
  • Jun 23, 2004
I just wanted to know where you guys tapped into to get a fuel pressure gauge to work? I am going to get one soon and started to think on how I am going to hook it up, is their a way you can use the shrader valve? Thanks for your help
9
92GTVert
29
Broken Arrow (Tulsa), Oklahoma
Jun 23, 2004
  • Jun 23, 2004
I installed a 2-5/8" electric Autometer Ultralite guage in my a/c cage and hooked it directly to the schrader valve. If I remember correctly, everything came with the guage for the hookup.
r6bullet
112
  • Jun 23, 2004
Oh ok, That is the same gauge I am getting but a the one that fits in the a-piller, that also brings me to another question. Do convertible models have a differant a-piller that notch/hatchbacks? Because their is a pod on ebay but dosen't specify which model it is for so I just needed to know if it would fit on a convert. Thanks guys
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Jun 23, 2004
  • Jun 23, 2004
I made my own pressure gauge and holder. I bought the NOS or Autometer adapter that you screw into the place on the fuel line where the schrader valve goes. I ran a piece of SS (stainless steel) braided hose to a brass T fitting that I mounted on the fender well by the MAF. I made a mount bracket out of aluminum angle I got from Home depot and bolted it to the fender well. Then I mounted the brass Tee to it with some machine screws and a plate. I sandwiched the brass Tee between the aluminum angle and a flat piece of aluminum that I trimmed off the extra aluminum angle. Three screws laid out in a triangle pattern go through both pieces of aluminum to clamp the Tee in place. I used a cheap industrial gauge from MSC Direct ( http://www.mscdirect.com/PDF.process?pdf=4588&Keyword=Y ). It works great and was cheaper than anything Summit had.
If you look through the MSC Direct catalog, you can find any type of gauge you want, including liquid filled. You only need a liquid filled gauge if you mount it directly on the engine. The liquid filling dampens out the vibrations.
You can buy the Autometer Stainless Steel braided hose for like $60. Or a local shop that makes hydraulic hose assemblies can make it for you at a cheaper price. Ordinary low pressure hydraulic hose can be used in place of the Stainless Steel braided hose, the Stainless Steel braided hose just looks nice. I got mine for $4 at a place that sells industrial and military surplus parts of all kinds. The Stainless Steel braided hose goes for about $3.60 a foot and the fittings are probably about $5-$8 each. You can make your own and save some $$$, the shops may have a setup or labor charge to fabricate the hose assembly.
r6bullet
112
  • Jun 23, 2004
I don't think I need all that with an electric gauge right?
9
92GTVert
29
Jun 24, 2004
  • Jun 24, 2004
I am pretty sure that the a-pillar on the 'vert is different. But, I am not 100% sure, more like 90% sure. Maybe somewhat else might chime in on this.
warmdye
482
Out in the Desert
Jun 24, 2004
  • Jun 24, 2004
I just installed a z series electronic fuel pressure guage on my pillar. You can either tap into the schrader valve or get an aftermarket FPR like aeromotive with a guage port. I have the aeromotive FPR with the port and it works great.
HISSIN50
34
129
Jun 24, 2004
  • Jun 24, 2004
in my exnperience, the 2 gauge pillar pods work on a vert - but you put them on over the existing pillar plastic (i think 3 gauge pods are supposed to replace the entire oem plastic pillar).
no experience with them.
good luck.
C
Electrical Fuel Gauge...Help! What did I do or Didn't Do?
  • ChickenDeluxe
  • Sep 3, 2026
Fox 5.0 Mustang Tech Sep 3, 2026
ChickenDeluxe
C
C
Looking for electrical schematic 1986 GT
  • CMT3
  • Sep 21, 2026
  • The Welcome Wagon
The Welcome Wagon Sep 23, 2026
AeroCoupe
D
Fuel Erratic Fuel Pressure 1985 GT
  • DienstXIV
  • Jan 14, 2026
Fox 5.0 Mustang Tech Jan 16, 2026
AeroCoupe
Fuel 1990 installing edelBrock intake
  • Beaker
  • Oct 5, 2026
Fox 5.0 Mustang Tech Oct 6, 2026
J
Having fuel issues
  • Jbands2v
  • Nov 2, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Nov 2, 2026
LILCBRA
