ARTTII said:
OK thanks!
I will probably just go for the diagnostic gauge now. I'll check out NAPA and Autozone.
I'm trying to make sure I have adequate pressure (39psi) at the rail. Correct me if I'm wrong but when I take the reading it should be with the car off but pump running (as in grounding out the correct location on the STI plug)? Or does the car have to be idling to get a correct reading?
Right now the car won't idle, so I would prefer to take the reading with the engine off if possible. Also I have a vaccuum line hooked up to the regulator, this is correct right?
Thanks for the help
Good call on the parts store diagnostic gauge. Some stores reportedly loan the gauges out (like they do specialty tools).
It would be nice to have the car running, but if that's not feasible, what you outlined sounds good. Leave the vac line just as it is - you're not setting fuel pressure - you just need to see if you have adequate pressure and the pressure reading with the vac line attached is lower than without the vac line attached (giving a better real world reading, given your situation). If pressure is below 30 PSI, that's not good. If you were to remove the vac line, you would want to see nearly 40 PSI.
You can simply install the gauge and let the pump prime during it's normal prime-out. You should have 30 PSI at the end of that priming. If you dont, continue to prime or jump the test connector to keep the pump running to see if you can build 30 PSI. As always, be aware of fire and safety concerns while doing this (I've had FP gauges leak before at the fitting).
There are several options depending upon your reading. If pressure is low, you can use fuel line crimpers (avl at the parts store) to
carefully crimp the return line. If pressure magically goes up, the FPR is likely bad. This is NOT likely your issue.
Otherwise, post up and the smart folks in here can help out.
Good luck.
