Okay I bought a fuel pressure gauge (I attached a picture of the kit I bought) but where do I put it? I tried the schrader valve on the fuel line next to the passenger side valve cover, but I don't get a reading. I tightened it up pretty good, so I'm pretty sure it should have worked. I know at least some fuel was getting in there, because a little leaked out when I removed the gauge. Is this the return line? Is that why it didn't work?
I don't see how I can get it to fit on the schrader vavle next to the fuel pressure regulator as the angle fitting (or gauge if I leave the fitting off) makes contact with the upper manifold making it impossible to tighten. Is there another schrader valve somewhere else? I didn't see one.
