In my '93 GT I upgraded to 24lb injectors. I have the stock fuel pressure regulator. Will this cause any issues performance or otherwise? If so what will I need to get the most out of my setup?
depends on your mods but it should be ok if your demands are not too hard. If you are N2o ot S/C then it can lean out which is a bad thing but I think its the same regulator in the 93 Cobra as non-cobra models so..... it should be ok if its a N/A engine.
Yeah, she's N/A. Not having any issues with the setup, but I am still learning the fi systems, so I just wanted to make sure I was getting the most out of my setup. Thanks for the info!!!
