Fuel Pressure Regulator Question
Husky44
865
104
74
Tacoma, WA
Is there such thing as too much fuel pressure?
91 5.0, stroked to 347, TF Street Heat Intake, TF heads. Walpro 255 LPH pump, 30# injectors.
I would like to run this Race Pump regulator, rated for 45-70# (looking for the dual outlet capability). Everything I read says stock motor should be set at about 40#; I'm not stock, but don't want to be in a situation where I can't set the pressure properly--is 45# going to be too much for my application?
Your maf should be set for your injectors. So at 40# your injectors are running at 30#... At 45# your probably going to run just a little rich. But that all depends on your combo I run mine at 43# and I have no problems. Anytime you increase the fuel pressure you increase the #ig on the injector. (to put it simply).
