fuel pressure vacuum
  • Thread starter Thread starter 1991vert
  • Start date Start date Apr 12, 2005
1991vert
1,103
Ludlow, MA
Apr 12, 2005
  • Apr 12, 2005
everytime i set my FP to 40 with the vacuum off it somehow always gets messed up. am i supposed to run the car with the vacuum off?? or just set the FP with the vacuum off then put the vacuum line back on?
whitehorseupnorth
SSoM President
1,772
Maine
Apr 12, 2005
  • Apr 12, 2005
You need to pull the vac line off to set your FP. With the vac line off it will simulate WOT. Cause, at WOT there is no vaccum. Now, after setting the FP and then connecting the vac line, the FP will go down cause the vaccum from the engine will act against the spring inside the FPR. Pull vac line, set FP, reconnect vac line. Pretty simple..
1991vert
1,103
Ludlow, MA
Apr 12, 2005
  • Apr 12, 2005
ya but then i'll check it again the next day with the vac off and it will read like
35 psi.
1991vert
1,103
Ludlow, MA
Apr 12, 2005
  • Apr 12, 2005
also should i do this when the car is hot? or at initial start up (cold)?
1990LXDropTop
430
Western Massachusetts
Apr 12, 2005
  • Apr 12, 2005
It is best to set it when the car is fully warmed up at normal operating temp.
Engine Fuel not pumping
  • Creomod
  • Apr 13, 2026
  • 2 3
2K
Fox 5.0 Mustang Tech Jul 22, 2026
L
Engine 85 GT Excessive Idle
  • lutzkecj
  • Sep 18, 2026
Fox 5.0 Mustang Tech Sep 21, 2026
86HO5.0
Mustang II 4 cyl gear hunting and possibly messed up vacuum system
  • oesterreicher
  • May 31, 2026
1974 - 1978 Mustang II Talk & Tech Jun 14, 2026
manicmechanic007
D
Please help with vacuum lines
  • Dawgs000082
  • May 10, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 10, 2026
Dawgs000082
D
Fuel Bad regulator diaphragm?
  • JD1964
  • May 20, 2025
2K
Fox 5.0 Mustang Tech Jul 16, 2025
JD1964
