G gwiesem New Member Sep 27, 2006 18 0 0 Oct 26, 2006 #1 Oct 26, 2006 #1 i got a holley fuel pressure regulator and was wondering what i should set it at.i have thumper heads,comp cam,cobra intake with x pipe and cat back.also sould i use the vacoom line on the regulator or just plug it off after i set the pressure.
DMAN302 My mom says thanks for the pearl necklace. Nov 8, 2003 2,120 2 59 windsor, Canada Oct 26, 2006 #2 Oct 26, 2006 #2 38-41 will be fine.
HISSIN50 "How long does it take to get help in here? 15 Year Member Nov 29, 1999 31,179 33 129 Oct 26, 2006 #3 Oct 26, 2006 #3 And use the vac line or WOT stoichiometry can be off. Good luck.
T Topdowncruise New Member Apr 7, 2005 207 0 0 Canada Oct 26, 2006 #4 Oct 26, 2006 #4 Do you have stock 19 lb injectors or 24's?
Flavadave4 Active Member Nov 28, 2003 1,044 21 49 Utica, NY Oct 27, 2006 #5 Oct 27, 2006 #5 You should set it to somewhere around 40 with the vac line off, then put the vac line back on!
thumper460 Founding Member Jul 24, 2000 3,022 2 56 Orange Park , Fl Oct 27, 2006 #6 Oct 27, 2006 #6 We suggest 38 Lbs with Vac off then tune from there... have fun!! Just me................................. Thumper
