fuel pressure
red1995gts
42
i just added 24lb injectors with the calibrated 75 maf a 70mm tb eddy heads long tubes o/r pipe. and i already had a 190 fuelpump. what is a good pressure to set the fuel at . and do you think my headers are glowing becasue of the fuel being to lean or rich???
fuel pressure should always be set at the factory setting of 40 PSI
I disagree, when I added my headers and pro-chamber to my catback I was instructed by their tech to bump up my fuel pressure, adding a bunch of power is going to lean out your fuel, therefore you want to add the correct amount of fuel to your combo. I think you need a lot more fuel....glowing headers are from being leaned out real bad, think about having too much fuel, it'd be blown out your exhaust and going through your headers to get there, cooling them down actually. Might wanna get some dyno time on a dyno with wideband support
