My friend has a 1990 LX Mustang...and the valve cover was leaking a decent trickle so I told him I'd replace the gasket for him. Well the swap went smoothly...we go to start it up and the fuel pump is dead as a doornail. It won't even prime and then shut off.
I immediately checked everything under the hood, every connector hooked back up properly and I didn't take off that much. The only two grounds I could find was the one that hooked up to the bolt underneath the power steering pump and the one behind the rear of the valve cover that attached to the firewall. Both were tight and undisturbed...just for ****s and giggles, I took off the one that bolted to the P/S pump bracket and hooked it back up, still nothing.
I searched here, replaced the fuel pump relay underneath the drivers seat and nothing. I then checked all of the fuses and my checker lit up everytime and just for assurance, I removed everyone of them and physically inspected them and they were ok. The only 3 relays on the fuse block (The car doesn't have a fuse cover to show which fuse does what, so I have no idea)...one was the flasher (round) and the other smaller one controlled the power windows. The third relay type metal one (sorry, don't know the technical name) is unkown...its on the left hand side that is the only thing on the fuse box that could possibly be bad and I don't know what it conrols.
Now, I think inertia switch. So I get to that, its not tripped. I reset it anyway, try it and nothing. Now I think ok is there power getting past the Fuel Pump relay at lest to the inertia switch. I turn the key to the on posistion and my volt meter says 11.8x volts consistant.
Crap...the freaking pump must be dead. Being an F-body owner, I'm thinking GREAT this **** is gonna take ALL day. To my pleasant surprise it was very easy comparitively. Get the tank dropped, new fuel pump in and STILL NOTHING. :damnit: :damnit: :damnit:
At this point I lean over the engine in frustration running through my mind over and over again what I did and trying to trace myself...and the alternator is very warm...but the car has been off since 10am this morning and its now 6pm. I take the alternator out and eat dinner and come back, and sure enough it has cooled down...so somehow, the alternator is hot.
In summary now, the car cranks, all the accessories work. There is 12 volts getting to the inertia switch, but its not going down the the Fuel pump at all. Put my meter on the pump connectors and nothing. The alternator gets very warm for some reason but if it was internally shorted, why would the car still crank and get the power back to the switch at all? I have checked everything three times, everything is hooked up properly..grounds ok..fuses all working..
My only two guesses at this point is the switch being faulty or the ECM not sending a signal to the fuel pump.
