fuel pump question please help
stamper5.0
ok...heres wats done to my car.......306 with protopline aluminum heads, 555 -570 lift nitrous cam. edelbrock performer rpm efi intake. and 100 wet shot of nitrous. i went to the track on motor it ran good but on nitrous it started breaking up around 4900rpms. i kno i need to update my entire fuel system. but i can only afford a feul pump. anyone have a clue on what one i should get?....
Get a quality name brand 255lph in-tank. Since you are only running a 100hp wet shot, you don't have to worry about the engine's injectors supplying the extra fuel, because the nitrous' fuel injector does it for you. I'll bet the larger fuel pump will remedy your problem. The rest of the fuel system is probably sufficient right now.
