Fuel Pump Relay, Now What!!??
  • Thread starter Thread starter silverlx50
  • Start date Start date Oct 19, 2009
silverlx50
168
62
38
Oct 19, 2009
  • Oct 19, 2009
Ive checked the sticky's and other threads for two days... Ok heres what was going on, I drove the car daily for two weeks and then parked it for another two, now when I turn the key to on or run the fuel pump primes and does not stop and the car wont start. I read the threads and stickys here and decided the easiest thing to check would be the relay which i found under the hood near the passenger strut. Ok two relays so I pull them both and check them, both working when I plugged them up to my trucks off road lighting. So I put the relays back in and decide to try and start. Now the fuel pump wont even prime at all and of course it wont start... I unplugged the relays again and plugged them back in and still no priming... What could have gone wrong just by removing the relays and pluging them back in? They worked fine in another application...
93 LX Vert with a 306 and S-Trim, any suggestions? (all mods were done about a year ago)
liljoe07
5 Year Member
Feb 18, 2009
1,622
363
124
Cartersville,Ga
Oct 19, 2009
  • Oct 19, 2009
run a jumper wire from the Fuel Pump Trigger to a good ground. Turn key on, and see if pump primes. If not, Go and test the wires on the back of the relay. 3 wires should have voltage.
A
apstang50
W. Yarmouth, MA
Oct 19, 2009
  • Oct 19, 2009
I could be wrong but I thought the fuel pump relay was under the drives seat?
liljoe07
5 Year Member
Feb 18, 2009
1,622
363
124
Cartersville,Ga
Oct 19, 2009
  • Oct 19, 2009
not in a 93 year Mustang
91-93 was in the engine bay. Mounted on the Passenger inner fenderwell, in front of the shock tower.
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Oct 19, 2009
  • Oct 19, 2009
Fuel Pump Troubleshooting for 91-93 Mustangs
Clue – listen for the fuel pump to prime when you first turn the ignition switch on.
It should run for 5-20 seconds and shut off. To trick the fuel pump into running,
find the ECC test connector and jump the connector in the lower RH corner to
ground.
If the fuse links are OK, you will have power to the pump. Check fuel pressure –
remove the cap from the Schrader valve behind the alternator and depress the
core. Fuel should squirt out, catch it in a rag. A tire pressure gauge can also be
used if you have one - look for 37-40 PSI. Beware of fire hazard when you do this.
No fuel pressure, possible failed items in order of their probability:
A.) Tripped inertia switch – press reset button on the inertia switch. The hatch
cars hide it under the plastic trim covering the driver's side taillight. Use the
voltmeter or test light to make sure you have power to both sides of the switch
B.) Fuel pump Relay:
On 91 cars, it is located under the driver seat.
On 92 and later model cars it is located below the Mass Air Flow meter.
C.) Clogged fuel filter
D.) Failed fuel pump
E.) Blown fuse link in wiring harness.
F.) Fuel pressure regulator failed. Remove vacuum line from regulator and inspect
for fuel escaping while pump is running.
Theory of operation:
Read this section through several times. If you understand the theory of operation,
this will be much easier to troubleshoot. Refer to the diagram below frequently.
Diagram of the fuel pump wiring for 91-93 cars.
The electrical circuit for the fuel pump has two paths, a control path and a power
path.
Remember that the computer does not source any power to actuators, relays
or injectors, but provides the ground necessary to complete the circuit. That
means one side of the circuit will always be hot, and the other side will go to
ground or below 1 volt as the computer switches on that circuit.
The control path consists of the computer, and the fuel pump relay coil. It turns
the fuel pump relay on or off under computer control. The switched power (red
wire) from the ECC relay goes to the relay coil and then from the relay coil to the
computer (light blue\orange wire). The computer provides the ground path to
complete the circuit. This ground causes the relay coil to energize and close the
contacts for the power path. Keep in mind that you can have voltage to all the
right places, but the computer must provide a ground. If there is no ground, the
relay will not close the power contacts.
The power path picks up from a fuse link near the starter relay. Fuse links are like
fuses, except they are pieces of wire and are made right into the wiring harness.
The feed wire from the fuse link (pink/black wire) goes to the fuel pump relay
contacts. When the contacts close because the relay energizes, the power flows
through the pink/black wire to the contacts and through the dark green\yellow
wire to the inertia switch. The other side of the inertia switch with the
brown\pink wire joins the pink/black wire that connects to the fuel pump. The fuel
pump has a black wire that supplies the ground to complete the circuit.
Power path:
Power feed: Look for 12 volts at the pink/black wire (power source for fuel pump relay).
No voltage or low voltage, bad fuse link, bad wiring, or connections. Remember that on 92
or later models the fuel pump relay is located under the Mass Air meter. Watch out for the
WOT A/C control relay on these cars, as it is located in the same place and can easily be
mistaken for the fuel pump relay.
Relay: Turn on the key and jumper the ECC test connector as previously described. Look
for 12 volts at the dark green\yellow wire (relay controlled power for the fuel pump). No
voltage there means that the relay has failed, or there is a broken wire in the relay control circuit.
Inertia switch:
The location for the inertia switch is under the plastic for the driver's side taillight.
There should be a round plastic pop out cover over it, remove it to access the switch button.
With the test connection jumpered and ignition switch in The Run position as described above, check
the brown/pink wire. It should have 12 volts. No 12 volts there, either the inertia switch is open
or has no power to it. Check both sides of the inertia switch: there should be power on the dark
green\yellow (inertia switch input) and brown/pink wire (inertia switch output). Power on the
dark green\yellow wire and not on the brown/pink wire means the inertia switch is open.
Press on the red plunger to reset it to the closed position. Sometimes the inertia switch will
be intermittent or will not pass full power. Be sure that there is 12 volts on both sides of the
switch with the pump running and that the voltage drop measured across the switch is less
than .75 volts.
Pump wiring: Anytime the ignition switch is in the Run position and the test
point is jumpered to ground, there should be at least 12 volts present on the
black/pink wire. With power off, check the pump ground: you should see less
than 1 ohm between the black wire and chassis ground.
Make sure that the power is off the circuit before making any resistance checks.
If the circuit is powered up, your resistance measurements will be inaccurate.
Control path:
Relay: The red wire for the fuel pump relay coil gets its power feed from the ECC relay.
No 12 volts here, and the ECC relay has failed or there is bad wiring or bad connections
coming from it. The ECC relay is located on top of the computer, which is under the passenger’s
side kick panel. It is not easy to get to, you must have small hands or pull the passenger side
dash speaker out to access it.
Relay: The light blue/orange wire provides a ground path for the relay power. With the test
connector jumpered according to the previous instructions, there should be less than .75 volts.
Use a test lamp with one side connected to battery power and the other side to the light blue/orange
wire on the fuel pump relay. The test light should glow brightly. No glow and you have a broken
wire or bad connection between the test connector and the relay. To test the wiring from the
computer, remove the passenger side kick panel and disconnect the computer connector.
It has a 10 MM bolt that holds it in place. Remove the test jumper from the ECC test connector.
With the test lamp connected to power, jumper pin 22 to ground and the test lamp should glow.
No glow and the wiring between the computer and the fuel pump relay is bad.
Computer: If you got this far and everything else checked out good, the computer is suspect.
Remove the test jumper from the ECC test connector located under the hood.
Probe computer pin 22 with a safety pin and ground it to chassis. Make sure the computer
and everything else is connected. Turn the ignition switch to the Run position and observe
the fuel pressure. The pump should run at full pressure.
If it doesn't, the wiring between pin 22 on the computer and the fuel pump relay is bad.
If it does run at full pressure, the computer may have failed.
Keep in mind that the computer only runs the fuel pump for about 2-3 seconds when you turn
the key to the Run position. This can sometimes fool you into thinking the computer has died.
Connect one lead of the test light to power and the other lead to computer pin 22 with a safety pin.
With the ignition switch Off, jumper the computer into self test mode like you are going to dump
the codes. Turn the ignition switch to the Run position. The light will flicker when the computer
does the self test routine. A flickering light is a good computer. No flickering light is a bad computer.
See the following website for some help from Tmoss (diagram designer) & Stang&2Birds (website host)
for help on 88-95 wiring Mustang FAQ - Engine Information
Fuel pump runs continuously:
The fuel pump relay contacts are stuck together or the light blue/orange wire
has shorted to ground. Remove the fuel pump relay from its socket. Then disconnect the computer and use
an ohmmeter to check out the resistance between the light blue/orange wire and ground. You should see
more than 10 K Ohms (10,000 ohms) or an infinite open circuit. Be sure that the test connector isn’t
jumpered to ground.
If the wiring checks out good, then the computer is the likely culprit.
Prior to replacing the computer, check the computer power ground. The computer has its own
dedicated power ground that comes off the ground pigtail on the battery ground wire. Due to
it's proximity to the battery, it may become corroded by acid fumes from the battery. It is a
black cylinder about 2 1/2" long by 1" diameter with a black/lt green wire. You'll find it up
next to the starter solenoid where the wire goes into the wiring harness
88mouse
630
Mooresville nc
Oct 20, 2009
  • Oct 20, 2009
Negative only 93 are mounted under the hood. 91 and 92 are still under the seat.
Hi-Po
106
Oslo, Norway
Oct 20, 2009
  • Oct 20, 2009
Nope, my 92 has the relay mounted on the passenger side fenderwell.
Not sure about 91's though.
liljoe07
5 Year Member
Feb 18, 2009
1,622
363
124
Cartersville,Ga
Oct 20, 2009
  • Oct 20, 2009
Ok...Ill say it again.
91-93 are in the engine bay.
Do some research.
liljoe07
5 Year Member
Feb 18, 2009
1,622
363
124
Cartersville,Ga
Oct 20, 2009
  • Oct 20, 2009
Actually 91 is a middle year change on the Fuel pump relay. Some are under the driver seat, some are made into the Main EFI harness. I know this because I just worked on a Stock 91 and the Fuel relay was the problem. But I have worked on some 91's that have them under the driver seat. Ford designers are idiots....LOL
1993SSP
1,194
Ky
Oct 21, 2009
#10
  • Oct 21, 2009
  • #10
I will agree with that last sentence. Why in the hell do they do some of the stuff they do?!!?! I love my mustangs but I cannot find reasoning in some of their methods such as using 10 different size heads on bolts in the engine bay. I will give GM credit, a 7mm, 10mm, 13mm, and a 15mm will just about dissasemble their cars. With ford it's untelling!
liljoe07
5 Year Member
Feb 18, 2009
1,622
363
124
Cartersville,Ga
Oct 21, 2009
#11
  • Oct 21, 2009
  • #11
No kidding. I just went to get some bolts at a parts store today. Needed to bolt the A/C compressor on.
Bolts for the head. 7/16-14 thread
Bolts for the compressor to bolt to the bracket. 10mm-1.5 thread..... WTF..
Anyways, the LX models that came equipped with a 4 cylinder. Had a CCRM, but had an empty relay socket under the seat. GTs should have the relay under the hood. 91-93 anyways.
88mouse
630
Mooresville nc
Oct 21, 2009
#12
  • Oct 21, 2009
  • #12
nm
silverlx50
168
62
38
Oct 30, 2009
#13
  • Oct 30, 2009
  • #13
OK replaced the fuel pump relay, still nothing. I jump the ecc test connector and the pump will prime continuosely. The fuel pump relay is getting power. the fuel pump is reading power while jumped. The intertia switch has power at both wires and is still in the down position.
Now the eec relay has different colored wires than you posted so i have no idea what to check on it. I also have no idea how to test the eec ground, I'm not sure which pin to check they are not labeled. Sorry but I never touch electronics and this is all new to me. Any other suggestions or maybe an easier way to explain testing the eec relay and the eec itself???
jrichker
Mar 10, 2000
27,512
2,813
234
Dublin GA
Oct 30, 2009
#14
  • Oct 30, 2009
  • #14
What color are the wires on the ECC relay?
The fact that the pump runs when the ignition switch is in the Run position and the test point is jumpered to ground only leaves two things for failure points:
1.) A single piece of wire between the computer and the fuel pump relay.
2.) The computer itself.
The test paths are designed for people who have a reasonable understanding of automotive electrical theory. It is beyond my ability to communicate the testing of electrical circuits if a person lacks the basic understanding of electrical principals.
For the electrically challenged, there is hope... more education...
Try Automotive Online Instruction for a beginning course. The course is very good and best of all, it is FREE!!!
I recommend you follow the Google search trail - automotive electrical course online - Google Search
Engine Fuel not pumping
  • Creomod
  • Apr 13, 2026
  • 2 3
2K
Fox 5.0 Mustang Tech Jul 22, 2026
  • Mindseye007
  • Aug 16, 2026
Mindseye007
U
No fuel pump relay in harness
  • Uli661
  • May 18, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 1, 2026
Uli661
U
A
1987 5.0 speed density Foxbody crank no start
  • Alan2204
  • May 23, 2026
Fox 5.0 Mustang Tech May 30, 2026
Mcmahst
D
Fox 88 foxbody no power to red and black wire at fuel pump relay
  • drod88
  • Dec 1, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Dec 2, 2025
Mcmahst
