  • SVT Tech Forum
Fuel pump relay
  • Thread starter Thread starter dohc281
  • Start date Start date Mar 30, 2008
dohc281
12
NJ
Mar 30, 2008
  • Mar 30, 2008
I've got a 98' Cobra and want to know where the fuel pump relay is. I think it is bad.
U
Uncle Meat
Banned
Jun 13, 2002
Prattville, Alabama
Mar 30, 2008
  • Mar 30, 2008
Look behind the drivers side tail light in the trunk. Should be mounted on the inside of that rear fender I believe. You'll have to pull the interior panel off to get at it.
U.M.
BlownFiveLiter
have car, will race....wait, it doesn't run
18
108
Chicagoland
Mar 30, 2008
  • Mar 30, 2008
Welcome to :SNSign:
U.M., that would be the inertia switch. The fuel pump relay is a non-servicable unit inside the CCRM. Not sure where exactly it's located in the 96+ cars, but the CCRM is bolted to the fan shroud on the 94-95 models.
U
Uncle Meat
Banned
Jun 13, 2002
Prattville, Alabama
Mar 30, 2008
  • Mar 30, 2008
You sure? I could have sworn there was a fuel pump relay located back there too?
U.M.
BlownFiveLiter
18
108
Chicagoland
Mar 30, 2008
  • Mar 30, 2008
Positive. Here's a wiring diagram, courtesy of Autozone, which shows the CCRM wiring for the 96-98 4.6L DOHC:
Edit: One of the other diagrams showed a fuel pump resistor, that appears it may be back there near the tank. I believe that was in one of the chassis wiring diagrams, not the engine controls.
U
Uncle Meat
Banned
Jun 13, 2002
Prattville, Alabama
Mar 30, 2008
  • Mar 30, 2008
Cool! Well now we know!
U.M.
dohc281
12
NJ
Mar 30, 2008
  • Mar 30, 2008
So are you saying I need to replace the CCRM?
BlownFiveLiter
18
108
Chicagoland
Mar 30, 2008
  • Mar 30, 2008
I can't make that determination. I can honestly say that I don't know what makes the 4.6 cars tick, so I'm not sure what needs to be done in the way of diagnosis to determine if a component of the CCRM is bad. Hopefully U.M., or someone else can lend a hand in that department, or possibly move this to 4.6 Tech for a little more visibility, if you don't find the answers you need in here.
COBRA90GT
Mustang Master
Sep 22, 2001
6,654
HOCKEYTOWN ® , MI
Mar 31, 2008
  • Mar 31, 2008
Why (symptoms? ) do you think your fuel pump relay is bad? What is your car doing (or not doing)? Have you ruled out other items first?
*edit*
BTW, read the response from "Joe D" in the following thread over on Corral. He typed out excellent troubleshooting techniques to determine if your CCRM may be faulty. Read them carefully and take a look at the contacts on your CCRM - remember, if one of the relays inside the CCRM box goes bad, you'll have to replace the entire box - $100 ballpark price, last time I checked.
http://forums.corral.net/forums/showthread.php?t=803483
BlownFiveLiter
18
108
Chicagoland
Mar 31, 2008
#10
  • Mar 31, 2008
  • #10
Bad moderator, linking to a competitive site...
Joe D from another forum said:
Tim,
As COBRA90GT said, "I *believe* that the CCRM (constant control relay module) is responsible for engaging the radiator fan when the A/C is activated, turning on the radiator low/high fan at a certain temperature, and has a relay for the fuel pump, among other things...
The CCRM is located in the passenger side (front) fenderwell. It is a little black box (4"x6") with a wiring harness connected to it."
The CCRM is a device that basically buffers EEC outputs and provides high current drive where necessary. Fuel pump, Fan, and AC Drive among others.
To answer your question, because the output side of the CCRM has such high current levels, a small amount of contact resistance translates to a large amount of heat generated at the output connectors. What can and has been seen with the fan circuits is the contact resistance generates enough heat that the connector housing can actually melt causing all sorts of intermittant circuit effects. If you have traced the weirdness in some circuits back to the CCRM, go the whole way to examinimg each connector pin and mating contacts for signs of heating and high contact resistance and you'll probably localize the problem. Make sure all the contacts in the specific circuit connectors are clean and tight. Look especially for subtle contact related things like a loose contact engagement or carbon streaks or partially melted housings that might make the contact pins move when the pins start getting hot. Good luck with it.
HTHs,
Joe
dohc281
12
NJ
Mar 31, 2008
#11
  • Mar 31, 2008
  • #11
*edit*
Periodically the car won't start. When this happens I do not hear the fuel pump ticking when I turn on the ignition. Sometimes it will almost start then then run like it is running out of gas. The main thing is that I can't hear the fuel pump running, 'when I do it will start and run fine.
C
cobrachu
#12
  • Apr 15, 2008
  • #12
Same problem here. I went to pull my 98 Cobra out of storage and when I turn the key I cant hear the fuel pump run. The fuse is good and in ten years this has never happened before. I did have the ccrm replaced last summer ($500) when my a/c was no longer fuctional. More problems maybe? Any way to jump the relay to rule out a bad pump?
U
No fuel pump relay in harness
  • Uli661
  • May 18, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 1, 2026
Uli661
U
W
Engine My engine dies after running 10 to 15 minutes under high heat.
  • Wylieone
  • Jun 21, 2026
Fox 5.0 Mustang Tech Jun 22, 2026
Mustang5L5
New fuel pump relay
  • Scrapla347
  • Nov 3, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Nov 8, 2025
Scrapla347
Fox won't crank over and fuel pump won't kick on.
  • djj62478
  • Jun 7, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 11, 2026
General karthief
Resolved Holley terminator integration into CCRM
  • BrandonMP
  • Feb 25, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Sunday at 7:17 PM
fasterthangas
F
  • SVT Tech Forum
