Fuel Pump Size..asap
latham83
496
Hey I know i read 1000 threads on this but i just wanted to make sure...
i was oging to buy a 190lph fuel pump cause im only running my stock injectors for now.... i need to know for sure if a 255lph pump is too much in any way for the stock injectors....
i probably will update the injectors way far down the road like over a year llater or something....and i wouldnt want to change the pump again...so will it def. be alright.?? all my other mods will be heavy just look at my sig...
banditmwp said:
If you get an adjustable fuel pressure regulator you should be ok with the larger pump...it will take a little tuning, but you shouldn't overload the injectors that way :nice:
subscribing
I need to swap out the stock one in my 92, and wanted to toss in a 190 or 255,(because I want to add on a Kenny Bell )in the near futer.
Had the same questions about tossin a bigger pump in. :shrug:
