Fuel pump stopped priming today...KOEO Results help?
My fuel pump was priming this morning as I was attempting to get the timing set after a motor swap. Its not priming anymore and Ive done some of the testing but I dont know where to go from here. I jumpered the computer test ground and fuel pump test connector but the fuel pump didnt turn on and I have less than 1/2 a volt at the pink/blk wire on the fuel pump relay. I DO get 12v at the yellow wire at the fuel pump relay KOEO. I dont have any voltage at the inertia switch but I do know that it isnt tripped. I hard wired the pump and turns on so that isnt the issue. I also check fuse links, all looked ok and look new so Im stumped. Ive been working on this motor swap for 3 weeks straight and desperately need some help getting it going...any and all suggestions welcome!
Fuel Pump Troubleshooting for 86-90 Mustangs
Revised 30-Aug-2008 to update fuel pump wiring diagram
Clue – listen for the fuel pump to prime when you first turn the ignition switch on.
It should run for 5-20 seconds and shut off. To trick the fuel pump into running,
find the ECC test connector and jump the connector in the upper RH corner to
ground.
attachment.php
If the fuse links are OK, you will have power to the pump. Check fuel pressure –
remove the cap from the Schrader valve behind the alternator and depress the
core. Fuel should squirt out, catch it in a rag. A tire pressure gauge can also be
used if you have one - look for 37-40 PSI. Beware of fire hazard when you do this.
No fuel pressure, possible failed items in order of their probability:
A.) Tripped inertia switch – press reset button on the inertia switch. The hatch
cars hide it under the plastic trim covering the driver's side taillight. Use the
voltmeter or test light to make sure you have power to both sides of the switch
B.) Fuel pump power relay – located under the driver’s seat in most Mustangs built
before 92.
C.) Clogged fuel filter
D.) Failed fuel pump
E.) Blown fuse link in wiring harness.
F.) Fuel pressure regulator failed. Remove vacuum line from regulator and inspect
for fuel escaping while pump is running.
How it works:
The electrical circuit for the fuel pump has two paths, a control path and a power
path.
The control path consists of the inertia switch, the computer, and the fuel pump
relay coil. It turns the fuel pump relay on or off under computer control. The
switched power (red wire) from the ECC relay goes to the inertia switch
(red/black wire) then from the inertia switch to the relay coil and then from the
relay coil to the computer (tan/ Lt green wire). The computer provides the ground
path to complete the circuit. This ground causes the relay coil to energize and
close the contacts for the power path. Keep in mind that you can have voltage
to all the right places, but the computer must provide a ground. If there is no
ground, the relay will not close the power contacts.
The power path picks up from a fuse link near the starter relay. Fuse links are like
fuses, except they are pieces of wire and are made right into the wiring harness.
The feed wire from the fuse link (orange/ light blue wire) goes to the fuel pump
relay contacts. When the contacts close because the relay energizes, the power
flows through the contacts to the fuel pump (light pink/black wire). Notice that
pin 19 on the computer is the monitor to make sure the pump has power.
The fuel pump has a black wire that supplies the ground to complete the circuit.
Remember that the computer does not source any power to actuators, relays
or injectors, but provides the ground necessary to complete the circuit. That
means one side of the circuit will always be hot, and the other side will go to
ground or below 1 volt as the computer switches on that circuit.
attachment.php
Troubleshooting: Now that you have the theory of operation well understood, it’s time to go digging.
Look for 12 volts at the Orange/Lt. Blue wire (power source for fuel pump relay).
No voltage or low voltage, bad fuse link, bad wiring, bad ignition switch or ignition
switch wiring or connections. There is a mystery connector somewhere under the
driver’s side kick panel, between the fuel pump relay and the fuse link.
Turn on the key and jumper the fuel pump test connector to ground as previously
described. Look for 12 volts at the Light Pink/Black wire (relay controlled power
for the fuel pump). No voltage there means that the relay has failed, or there is a
broken wire in the relay control circuit.
Check the Red/black wire, it should have 12 volts. No 12 volts there, either the
inertia switch is open or has no power to it. Check both sides of the inertia
switch: there should be power on the Red wire and Red/Black wire. Power on the
Red wire and not on the Red/Black wire means the inertia switch is open.
Pump wiring: Anytime the ignition switch is in the Run position and the test
point is jumpered to ground, there should be at least 12 volts present on the
black/pink wire. With power off, check the pump ground: you should see less
than 1 ohm between the black wire and chassis ground.
attachment.php
The yellow wire is the fuel tank sender to the fuel quantity gage. The two black wires are grounds.
One ground is for the fuel tank sender and the other is the fuel pump. The ground for the fuel pump
may be larger gauge wire that the fuel tank sender ground wire.
Make sure that the power is off the circuit before making any resistance checks. If the circuit
is powered up, your resistance measurements will be inaccurate.
You should see less than 1 Ohm between the black wire(s) and ground. To get some idea of what
a good reading is, short the two meter leads together and observe the reading. It should only be
slightly higher when you measure the black wire to ground resistance.
The Tan/Lt Green wire provides a ground path for the relay power. With the test
connector jumpered to ground, there should be less than .75 volts. Use a test
lamp with one side connected to battery power and the other side to the
Tan/Lt Green wire. The test light should glow brightly. No glow and you have a
broken wire or bad connection between the test connector and the relay. To test
the wiring from the computer, remove the passenger side kick panel and
disconnect the computer connector. It has a 10 MM bolt that holds it in place.
With the test lamp connected to power, jumper pin 22 to ground and the test
lamp should glow. No glow and the wiring between the computer and the fuel
pump relay is bad.
Computer: If you got this far and everything else checked out good, the computer is suspect.
Remove the test jumper from the ECC test connector located under the hood.
Probe computer pin 22 with a safety pin and ground it to chassis. Make sure the computer
and everything else is connected. Turn the ignition switch to the Run position and observe
the fuel pressure. The pump should run at full pressure.
If it doesn't, the wiring between pin 22 on the computer and the fuel pump relay is bad.
If it does run at full pressure, the computer may have failed.
Keep in mind that the computer only runs the fuel pump for about 2-3 seconds when you turn
the key to the Run position. This can sometimes fool you into thinking the computer has died.
Connect one lead of the test light to power and the other lead to computer pin 22 with a safety pin.
With the ignition switch Off, jumper the computer into self test mode like you are going to dump
the codes. Turn the ignition switch to the Run position. The light will flicker when the computer
does the self test routine. A flickering light is a good computer. No flickering light is a bad computer.
Fuel pump runs continuously: The fuel pump relay contacts are stuck together or the Tan/Lt Green wire
has shorted to ground. Remove the fuel pump relay from its socket. Then disconnect the computer and use
an ohmmeter to check out the resistance between the Tan/Lt Green wire and ground. You should see
more than 10 K Ohms (10,000 ohms) or an infinite open circuit. Be sure that the test connector isn’t
jumpered to ground.
If the wiring checks out good, then the computer is the likely culprit.
Prior to replacing the computer, check the computer power ground. The computer has its own
dedicated power ground that comes off the ground pigtail on the battery ground wire. Due to
it's proximity to the battery, it may become corroded by acid fumes from the battery. It is a
black cylinder about 2 1/2" long by 1" diameter with a black/lt green wire. You'll find it up
next to the starter solenoid where the wire goes into the wiring harness
If all of the checks have worked OK to this point, then the computer is bad. The
computers are very reliable and not prone to failure unless there has been
significant electrical trauma to the car. Things like lightning strikes and putting
the battery in backwards or connecting jumper cables backwards are about the
only thing that kills the computer.
See the following website for some help from Tmoss (diagram designer) &
Stang&2Birds (website host)
http://www.veryuseful.com/mustang/tech/engine/images/88-91eecPinout.gif
Get a 15 amp fuel and about 20 ft of 14 gauge wire. You are going to bypass the relay circuit and apply power directly to the pump.
Do not attempt this without the fuse!!! A short circuit could start a fire. Do not let this test run for more than 20-30 seconds
to prevent dumping any gas into a non running engine.
Disconnect the fuel pump at the connector back by the passenger side spare tire wheelwell. Store the body side connector out of the
way so that it will not be damaged. Take the wire that goes to the fuel tanks and both black wires to ground. Connect the pink wire
that goes to the fuel tank to the fused jumper wire. Finally connect the fused jumper wire to the positive side of the battery. If the fuel
pump runs and you have fuel pressure, the problem is in the relay circuit and wiring. If not, it is in the fuel pump or the short harness that
you connected your jumper wires to.
What other pink wire? I dont have voltage at the pump pink/black or at the pink/black on the fuel pump relay socket. I also looked for 12v on the injector harness, and 5v on the tps and came up with nothing. Interestingly enough as I was testing the tps I head a "click" type sound so for giggles I turned off and on again and sure enough it was priming. Hooked up the other battery I had charging and once again no prime. EEC relay turns on...Please help?
Back up and look for voltage at the red/green wire coming from the ignition switch to the ignition coil. That same circuit provides power to the ECC relay.
12 volts output of the ECC relay, and 12 volts on the orange/lt blue and no voltage at the pink/black wire on the relay socket is a failed relay or bad connections at the relay socket. Relay socket pigtails are available at many auto parts stores. I would try NAPA before AutoZone or any of the other auto parts chain stores.
See the following website for some help from Tmoss (diagram designer) & Stang&2Birds (website host) for help on 88-95 wiring http://www.veryuseful.com/mustang/tech/engine/ Everyone should bookmark this site.
Ignition switch wiring
Complete computer, actuator & sensor wiring diagram for 91-93 Mass Air Mustangs
http://www.veryuseful.com/mustang/tech/engine/images/91-93_5.0_EEC_Wiring_Diagram.gif
Vacuum diagram 89-93 Mustangs
HVAC vacuum diagram
TFI module differences & pinout
Fuse box layout
I really dont know what I'm looking for but I do appreciate your help so far...I guess I'll keep doing the same thing over and over and expect different results :/
The fuel pump test path is broken into two sections: How it works and troubleshooting. Read and re-read the How it works section until you get it figured out. Then go through the troubleshooting section and you will find it easier to follow.
Okay, I get the following:
EEC Relay:
red wire/org&blk wire 1.42 volts
red wire 12v
black/orange 1.42
green/tan? 1.42
Fuel pump relay:
tan/black 1.42v
red/blk 1.42v
yellow 12v
pink/black 0
If I jumper the pink/black to the yellow the pump turns on
The red wire from the eec power relay should be giving 12v to the inertia switch but I dont have any voltage there. From there it goes to the fuel pump relay eventually powering on the pink/black wire which turns the pump on. Am I getting warm?
I figured it out! Thank you JRichker. It was my fuse link on the starter solonoid (orange/black). I played with them and the pump came on. Tested them again and only got the 1.42 volts I was getting at the other wires on the fuel pump relay. After further inspection, the wires were so corroded inside they were hardly making a connection anymore and have become almost 100% rust. Hopefully this might help someone in the future
