Fuel Pump
  • Thread starter Thread starter stangman16
  • Start date Start date Jul 23, 2006
stangman16
640
San Antonio, TX
Jul 23, 2006
  • Jul 23, 2006
I've come across a Holley Red electric fuel pump that I'm considering for my EFI conversion on my '66. Would this electric fuel pump supply the necessary pressure for the EFI system, or is this for a carb'd engine?
How much PSI is required to run a stock '91-'93 5.0 EFI ?
HISSIN50
34
129
Jul 23, 2006
  • Jul 23, 2006
40 PSI or a bit more for WOT.
Stock pumps for later-HO engines was 95 LPH (as I recall).
Killer50stang
632
  • Jul 23, 2006
I would get the Holley blue as it comes with a regulator that you can adjust the fuel pressure. Don't think they are much more.
stangman16
640
San Antonio, TX
Jul 23, 2006
  • Jul 23, 2006
this one is actually free..
here's some comparison on the three - i would like to start with the Red one first since it's free and I just want to get this car driveable, then upgrade later when I add performance parts. do you think the red pump will work for the time being?
HOLLEY BLACK ELECTRIC FUEL PUMPS-------140 GPH @ 12-14 POUNDS PRESSURE
HOLLEY BLUE ELECTRIC FUEL PUMPS---------110 GPH @ 10-12 POUNDS PRESSURE
HOLLEY RED ELECTRIC FUEL PUMPS-----------97 GPH @ 5-7 POUNDS PRESSURE
Killer50stang
632
  • Jul 23, 2006
Well free is good, but I would pick up a regulator if you don't already have one.
stangman16
640
San Antonio, TX
Jul 23, 2006
  • Jul 23, 2006
I have the stock regulator that is on the fuel rail - I assume all of this should work okay?
Killer50stang
632
  • Jul 23, 2006
I didn't think you that regulator was adjustable, but I may be wrong. I had issues with mine, which is my I got the blue pump.
stangman16
640
San Antonio, TX
Jul 23, 2006
  • Jul 23, 2006
actually i don't believe it is adjustable. So I should shoot for the holley blue one w/the regulator? Or should I try this one first?
Does your regulator mount in the same location as the stock EFI fuel regulator?
Killer50stang
632
  • Jul 23, 2006
It comes with mounting brackets. You can mount it whereeve you want, mine's on my firewall. No sense in getting a blue pump if this one is free. You can pick up those regulators for like $15 or so.
Fuel Anyone know a part number for a 3/8" inlet/outlet efi quick connect fuel filter that would fit the stock foxbody location?
  • rednotch
  • Dec 8, 2025
Fox 5.0 Mustang Tech Dec 8, 2025
rednotch
9
Forced Induction Prepping for supercharger on non-stock build
  • 91fox427
  • Nov 25, 2025
Fox 5.0 Mustang Tech Jan 5, 2026
Qtrhrse23
D
Fuel Erratic Fuel Pressure 1985 GT
  • DienstXIV
  • Jan 14, 2026
Fox 5.0 Mustang Tech Jan 16, 2026
AeroCoupe
M
01 mustang 3.8 fuel pressure issue
  • Mhaley2006
  • May 29, 2026
1996 - 2004 SN95 Mustang -General/Talk- Aug 9, 2026
JohnKay
J
Fox Fuel Pump Issues After Replacement/Upgrade
  • Ryu
  • Jun 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 13, 2026
Ryu
