Fuel pump
For almost the same price you can get a 255lph. I would go with the Walbro 255 high pressure. As far as I know the fuel pump won't "overfeed" the engine (that's based on the regulator, injectors and tune) and this will allow you to put a power adder on without having to change the fuel pump again.
Or if you know you wont be doing lots of other stuff, a 155 works and saves some cash. As I see it, that will be sufficient for your Exploder combo (if anyone disagrees, speak up!)
Good luck.
