on my 87 fox i have notice lately that when i get on it it is fine but when i let off the gas i can smell a strong gas smell? was doing it with the 19 lbs injectors so i upgraded mass air and to 24 lbs injectors. any clue? want to solve this issue quickly. was running fine up till about 3 days ago. still runs great just has the fuel smell. sometimes it does it just comming to a stop from driving. have looked and can't see any fuel leaks from the tank to the injectors.
car specs.
87 stock short block and cam
mass air conversion
24 lbs injectors
equal length shorties
off road h-pipe
gt40 heads
1.7 roller rockers
frnder well cold air.
70mm tb
perfessional products typhoon intake
all smog stuff is still hooked up.
car specs.
mass air conversion
24 lbs injectors
off road h-pipe
gt40 heads
1.7 roller rockers
70mm tb
You should also check the hoses leading from the vapor canister to make sure they're not cracked or vulcanized.
