fuel smell
98gt4me
32
Pennsylvania
I have a 98gt 5 speed with about 110k. After driving, I can smell fuel interrmittently in the drivers seat. I usually smell it near the back of the car. I just recently passed PA state insoection/emissions. The check engine light has not come on. My fuel mileage seems to be fine. Any ideas?
Well, if you can get it on a lift just check the whole length of the fuel line. Maybe you pinched it with a jack or maybe there is a bad connection on the fuel filter.
updated info..need install help
Ok. I found the seal around the filler neck torn where the neck goes into the side of tank. I have purchased the seal and a new vent tube. Has anyone ever installed the seal where the neck goes into the tank? If so, can you provide some insight. Thanks!
Help. Has anyone ever installed a seal where the neck goes into the tank? Any info qould be appreciated!!
It's very easy. Open the cover, you should see 4 little bolts holding the neck in place. If you remove those, you can pull the neck right out to get to the seal. Just buy a Haynes repair manual, it has everything you will ever need.
