  • 2.3L (N/A & Turbo) Tech
Fuel switch
  • Thread starter Thread starter JosephB
  • Start date Start date Jun 10, 2006
J
JosephB
42
Alabama...for now.
Jun 10, 2006
  • Jun 10, 2006
I have a question about the mysterious and missing fuel switch that is to be used with the 87 t-bird coupes. There is supposed to be a regular/premium switch that will only alow the turbo to make about 9 psi on regular setting. My mustang has a 87 tc engine with a t3 turbo and no switch but I will be using 93 octane and a gillis valve so I should be able to boost it up around 18-20 right? I have the overboost light but that's it. I finally have the new 87 t-bird eng, tranny and driveshaft installed. All I have left are the sensors, injectors, belt, and upper intake. I should have it running tommorrow. By the way, I have a in-line 190 LPH pump with 35# inj setup. If the switch isn't on the car, it should still be ok with the gillis right?
J
JosephB
42
Alabama...for now.
Jun 11, 2006
  • Jun 11, 2006
I just found info on Project Horsepower 91-93 tc swap. Apparently if the fuel switch wasn't installed I have to run on premium all the time. I guess i'll be able to boost it up then.
65ShelbyClone
4,675
38
119
Antelope Valley, SoCal
Jun 11, 2006
  • Jun 11, 2006
I was under the impression that without the switch it will run on the low octane setting.
evintho
20+ Year Stangneter
Nov 12, 2003
683
245
73
Santa Rosa, CA.
Jun 12, 2006
  • Jun 12, 2006
It's very simple to wire the premium fuel switch in. Pick one up from an '87-'88 TC parts car and install it. Now you have a choice of running regular or supreme. After all, life is all about choices, isn't it? The wiring instructions are in the link below.
Click on the link below, then 'Slugstang', then '85 how-to's' and towards the bottom of the page is the info.
http://www.flemworld.com
'03 GT Fuel Pump/Pressure/Delivery Issue
  • Brodach
  • Oct 21, 2025
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Oct 31, 2025
gkomo
A
Resolved Fuel Pump issue - test port jumped comes on (87 LX)
  • afjLX
  • Nov 16, 2024
2K
Fox 5.0 Mustang Tech Nov 26, 2024
afjLX
A
A9L on 94 engine, no priming injector pulse?
  • Wallyman
  • Jun 17, 2024
  • Other Auto Tech
Other Auto Tech Jun 24, 2024
Wallyman
Intended Headers and Trans, questions about fitment
  • from6to8
  • Aug 6, 2024
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 6, 2025
from6to8
For Sale 3-owner 1987 Mustang GT, $18K obro, Lancaster CA
  • Bill Cool
  • Oct 6, 2024
2K
Fox Body Mustangs For Sale (1979-93) Oct 13, 2024
nickyb
