Fuel System High Horse Power
Just a general question:
How does one nearly complete a 5-6 hundred HP build without an idea of what the fuel system is going to be?
Of what exactly, does this engine build consist?
Edit: Oh... and moved to Talk section.
You'll probably only need to upgrade the fuel injectors and fuel pump. In terms of injectors, based on this website that has a calculator for this sort of thing, you're going to need 52lb injectors minimum. In terms of fuel pump, a good option would be maybe finding a cobra tank w/ the fuel pumps, I think those handle roughly up to 600HP, then throw on a Kenne Belle Boost-A-Pump to make them push even more than that!
Hope this helps, good luck :)
