Fuel System Q
  • Thread starter Thread starter hoopty5.0
  • Start date Start date Nov 13, 2011
hoopty5.0
mechanicus terribilis
7,854
6,994
214
SW Houston
Nov 13, 2011
  • Nov 13, 2011
I need a little help planning the fuel system for the 408. It needs to be able to support 550 hp with a little room to grow.
Do I need to replace the lines and rails?
What pump is most popular? I read to stay away from external Aeromotives..
Replace the stock tank or just sump it and use it like it like that?
Also can't decide between the Megasquirt or PMS... Looks like many people like the MS though. Thoughts?
Thanks
Collin
90lxcoupe
20+ Year Stangneter
Oct 7, 2003
3,596
350
134
Nov 14, 2011
  • Nov 14, 2011
I think you will be good with the stock lines, a 255 in the tank and maybe a pusher pump with 42# injectors. Thats what im running, i used it when the car was making 480 at the tires with a supercharger and now im using it with my NA motor. It has worked out great and didnt break the bank.
Id say MS over the PMS. The PMS is a good system, but the megasquirt is 100% standalone, cheaper, and easier to use IMO
srtthis
the guy doing it does every local racers rear end
5,129
1,666
204
Maryland
Nov 14, 2011
  • Nov 14, 2011
if you want to have room to grow id personaly go summped tank magnafuel pump -8 feed lines magnafuel regulator and a -6 return.
hoopty5.0
7,854
6,994
214
SW Houston
Nov 14, 2011
  • Nov 14, 2011
Both are great points. I had heard that stock lines are good to 500 hp (crank) and the obvious difference in the two is price.
Maybe I'd just start with the 255 in tank and see how it works. Can always upgrade if I need more. If it goes lean at the top end I'll know where to start trouble shooting at least.
As far as the megasquirt goes, does it eliminate the need for dyno tuning? I know there are a few guys in the area who are good with it.
90lxcoupe
20+ Year Stangneter
Oct 7, 2003
3,596
350
134
Nov 15, 2011
  • Nov 15, 2011
Stock lines are good for around 500rwhp with boost, so with a NA motor, that number will go up.
I think trying to keep the stock lines is a good idea, there not hurting anything and fuel systems are pretty expensive.
MS dosent exactly eliminate the need for dyno tuning, what i did was get the WOT done on the dyno and we also worked on the driveability. The WOT part of the tune was good when i left the dyno, but the drivability still needed some work, so i did most of that myself and got the car driving really well using the VE analyze part of tuner studio. The software basically tunes the car for you if you set it up right. The dyno is just a tool to use to tune the car. Its really hard to do it on the street, especially if you are trying to drive and tune the car at the same time, so the dyno is a good safe place to start
H
Fuel starvation issues, 91 EFI to carb swap. Car dying after 1-3 gallons used. EFI tank, electric fuel pump, bypass regulator. Dual fed carb
  • hassler
  • Oct 11, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 12, 2025
nickyb
M
01 mustang 3.8 fuel pressure issue
  • Mhaley2006
  • May 29, 2026
1996 - 2004 SN95 Mustang -General/Talk- Aug 9, 2026
JohnKay
J
Fuel pump reccomendation
  • jimzzilla
  • Feb 19, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 21, 2025
85GTStangGuy
F
Ford 460 swap
  • Ford460
  • Sep 13, 2026
Ford460
F
'03 GT Fuel Pump/Pressure/Delivery Issue
  • Brodach
  • Oct 21, 2025
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Oct 31, 2025
gkomo
