Fuel upgrades, car won't run. Need help ASAP! :(
More detailed progress now that I have time.
This morning's progress (or lack thereof):
I set my TPS. Come to find out the reason I never was able to get it set past .04 was because I wasn't turning it before setting the screws. Lesson learned, now it's set at .97 perfectly.
But the car still won't idle.
The fuel pump no longer turns on and primes when the key is in ON position. We used a test light and all my relays are getting power and are not busted. They are tested and functioning properly.
I looked at some wiring diagrams labeled for an 88-91. Although the wiring colors are different we've come to the conclusion that the EEC power relay is not doing its job, mainly shooting power to the EEC and back to the fuel pump relay, which is why the pump isn't kicking on.
And with that, it's not sending signals to the EEC and that explains my computer not being able to be read on the code-puller.
Does this sound like it makes sense to any of you? I had to go into work but my friend is going to stop by (might even be there by now) my garage and get back to work for me.
If I hear anything good from you guys I will call him up and let him know.
Thanks!
-dave
Clue – listen for the fuel pump to prime when you first turn the ignition switch on. It should run for 5-20 seconds and shut off. To trick the fuel pump into running, find the ECC test connector and jump the connector in the lower RH corner to ground. See http://www.mustangworks.com/articles/electronics/eec-iv_codes.html for a description of the test connector. If the relay & inertia switch are OK, you will have power to the pump. Check fuel pressure – remove the cap from the schrader valve behind the alternator and depress the core. Fuel should squirt out, catch it in a rag. A tire pressure gauge can also be used if you have one - look for 37-40 PSI. Beware of fire hazard when you do this.
No fuel pressure, possible failed items in order of their probability:
A.) Tripped inertia switch – press reset button on the inertia switch. The hatch cars hide it under the plastic trim covering the driver's side taillight. Use the voltmeter or test light to make sure you have power to both sides of the switch
B.) Fuel pump power relay – located under the driver’s seat in most stangs built before 92. On 92 and later model cars it is located below the Mass Air Flow meter.
C.) Clogged fuel filter
D.) Failed fuel pump
E.) Blown fuse link in wiring harness.
F.) Fuel pressure regulator failed. Remove vacuum line from regulator and inspect for fuel escaping while pump is running.
The electrical circuit for the fuel pump has two paths, a control path and a power path.
The control path consists of the inertia switch, the computer, and the fuel pump relay coil. It turns the fuel pump relay on or off under computer control. The switched power (red wire) from the ECC relay goes to the inertia switch (red/black wire) then from the inertia switch to the relay coil and then from the relay coil to the computer (tan/ Lt green wire). The computer provides the ground path to complete the circuit. This ground causes the relay coil to energize and close the contacts for the power path. Keep in mind that you can have voltage to all the right places, but the computer must provide a ground. If there is no ground, the relay will not close the power contacts.
The power path picks up from a fuse link near the starter relay. Fuse links are like fuses, except they are pieces of wire and are made right into the wiring harness. The feed wire from the fuse link (orange/ light blue wire) goes to the fuel pump relay contacts. When the contacts close because the relay energizes, the power flows through the contacts to the fuel pump (light pink/black wire). The fuel pump has a black wire that supplies the ground to complete the circuit.
See the following website for some help from Tmoss (diagram designer) & Stang&2Birds (website host)
http://www.veryuseful.com/mustang/tech/engine/images/88-91eecPinout.gif
Now that you have the theory of how it works, it’s time to go digging.
Look for 12 volts at the Orange/Lt. Blue wire (power source for fuel pump relay). No voltage or low voltage, bad fuse link, bad wiring or connections. There is a mystery connector (one I haven’t found) under the dash somewhere, between the fuel pump relay and the fuse link.
Turn on the key and jumper the fuel pump test connector to ground as previously described. Look for 12 volts at the Light Pink/Black wire (relay controlled power for the fuel pump). No voltage there means that the relay has failed or there is a broken wire in the relay control circuit.
Check the Red/black wire, it should have 12 volts. No 12 volts there, either the inertia switch is open or has no power to it. Check both sides of the inertia switch: there should be power on the Red wire and Red/Black wire. Power on the Red wire and not on the Red/Black wire means the inertia switch is open.
The Tan/Lt Green wire provides a ground path for the relay power. With the test connector jumpered to ground, there should be less than .75 volts. Use a test lamp with one side connected to battery power and the other side to the Tan/Lt Green wire. The test light should glow brightly. No glow and you have a broken wire or bad connection between the test connector and the relay. To test the wiring from the computer, remove the passenger side kick panel and disconnect the computer connector. It has a 10 MM bolt that holds it in place. With the test lamp connected to power, jumper pin 22 to ground and the test lamp should glow. No glow and the wiring between the computer and the fuel pump relay is bad.
If and only if you have followed the test procedure to this point and still haven’t found the problem, the computer is suspect. :(
Clue listen for the fuel pump to prime when you first turn the ignition switch on. It should run for 5-20 seconds and shut off. To trick the fuel pump into running, find the ECC test connector and jump the connector in the lower RH corner to ground. See http://www.mustangworks.com/article...c-iv_codes.html for a description of the test connector. If the relay & inertia switch are OK, you will have power to the pump. Check fuel pressure – remove the cap from the schrader valve behind the alternator and depress the core. Fuel should squirt out, catch it in a rag. A tire pressure gauge can also be used if you have one - look for 37-40 PSI. Beware of fire hazard when you do this.
We did this, switches are fine. I have a FP gauge on the fuel line instead of the schrader valve, and it is reading 38 as I have it set. FP regulator is brand new, as is the fuel filter. Fuel pump relay is working and also brand new, just a couple months old with less than 200 miles on it. Fuel pump is brand new, just installed a couple months and only run for a couple minutes before I started having problems.
Printed those out, labeled 88-91. Mine is a 92 and most wires are colored different. But from those we got the idea that the EEC power relay was shot, since it wasn't powering back to the computer.
Thanks on the other explanations, I'm going to be busy tonight! :)
That's what I'm trying to find now. No luck so far.
It's not reading the computer, exactly that. As if it were busted (which it might be), it's giving off no reading to the machine. :shrug:
You have an extra or know anyone? I'm in dire straits here, I can take a drive!
I've only got a DA1 computer which is speed density. I just sold my maf computer to a friend which is in his car right now, sorry...
Are you using a scanner, or the old paperclip and test light trick? You probably can't keep it running long enough, huh?
just trying to help out
It's an actual professional scanner. Not sure if I mentioned in this thread or not, but the guy helping me diagnose it is a mechanic with all the right tools.
Thanks for the help, any suggestion is one step closer to figuring it out, as long as we can rule it out as a problem.
Check the voltage of the Signal Retun wire & the v-ref wire down at the EEC, if voltage is good there (KOEO), then run a jumper wire from the Signal Return to a good chassis ground. Try to pull the codes ... if the codes will pull with the Signal return wire grounded chances are the EEC is shot....
BUT
Are you getting power back to the FP or no? Have you checked the wiring for the pump/relay/inertia switch?
Good Luck!!
Mike
=Printed those out, labeled 88-91. Mine is a 92 and most wires are colored different. But from those we got the idea that the EEC power relay was shot, since it wasn't powering back to the computer.
Pull off any of the fuel injector connectors and look for +12 volts on the red wire. No +12 volts, ECC relay is suspect. If +12 volts is good, then the computer is suspect.
Look for VREF (+5 Volts) at the TPS ,MAP or EGR sensors.
Check the ground at pins 40 & 60 on the computer with it powered up. You will need to probe the pins from the back of the connector, a safety pin or paper clip is helpful. There should be less than .5 volt between the computer ground pins and battery negative post.
Look for +12 volts on pin 1 of the computer: no +12 and the ECC relay is inop. You'll need your safety pin or paper clip again to gain access to the back of the pin.
All testing done last night concluded the EEC is shot. I was able to finally get in touch with a local who has one, and I will be picking it up ASAP for testing.
The EEC power relay was receiving the power that it was supposed to, so that ruled it out.
What I'm worried about is, for some reason, what if the EEC happens to NOT be the problem after all? Then I'm really in trouble :(
All signs are pointing to it, and everyone is saying that "if this, this, and this occurs, then it's the EEC", but I'm always worrying when it comes to the car :doh:
We'll see soon.
Well if you've checked the wiring well where your having issues, checked your power & grounds good & it's not any of the specific components it only leaves the EEC I just had to replace mine after what 7 years? Put the new one in & I have no issues what so ever now. FWIW ...good luck man!
Mike
Mike, I'm just a worrywart, especially when I have events coming up.
FWIW also, this is the stock computer from '92. 70K miles just turned before I winterized it. Never would have thought I'd have to replace it, but I guess with the mods I've done it might have helped out huh?
Can't wait to get the hell out of work and try that beast out! :D
Well I knew it :(
I put the new computer in, and no go.
I also see that the fuel pump no longer primes when I put the key to ON position. The relay is getting power, the relay is sending power, the fuel pump has power to it, the intertia switch is not triggered, and the fuses are not blown.
Any idea now?
