Full frame in a classic mustang?
  • Thread starter Thread starter mustang6788
  • Start date Start date Jul 1, 2006
M
mustang6788
27
  • Jul 1, 2006
I happened to see this on ebay for sale they want about $10,000 for the kit with rack and pinion ect. Never seen anyone make a frame kit for a classic mustang. The frame appears to be all boxed and cross supports and comes with good brakes. Would a mustang body with the subframes removed and a few select mounting points still flex being as it was never designed to be used without some kind of support? New to me but I would like to see what it is like intstalled in a classic mustang.
http://www.precraftusainc.com/projectspage3.html
http://cgi.ebay.com/ebaymotors/Mustang-full-frame-67-68-69-70-Aftermarket_W0QQitemZ190003301844QQihZ009QQcategoryZ6236QQrdZ1QQcmdZViewItem
Red Barchetta
761
Behind the Orange Curtain
Jul 1, 2006
  • Jul 1, 2006
The first clue as to why this is a bad idea is where they say "Bolts on to your Mustang body!"
If it were welded in, then I can see an improvement in torsional rigidity, but with a huge weight penalty. Nothing a good pair of SFC couldn't greatly improve at a fraction of the weight penalty. The only other possible improvement would be in the front and rear suspension, but I don't know enough about the design to say either way. There's a similar discussion on Corner-Carvers about someone who's making their own frame. This would be a good comparison.
xoxbxfx
3,959
Southlake, TX
Jul 1, 2006
  • Jul 1, 2006
Looks like a PITA to me... they make it sound easier than it is....
You have to replace the wole frontend sheetmetal, cut out the existing front frame and torque box, some way to lift the car... For 10k, Id have the whole car blasted, go with a coilover setup in the front or MII and then an IRS or something in the rear. Lots of work
U
unluckyengineer
45
  • Jul 1, 2006
I agree it just seems like the appeal of a frame car comes from having a body that you just set on there and go corvette style. You can weld in subframe connectors and have the same effect. just seems like for four or five grand you could get a much better setup with similar handling and braking characteristics. I don't know though I am a unibody man I try to stay out of the frame cars...
rbohm
6,698
550
204
tucson,az
Jul 2, 2006
  • Jul 2, 2006
for $2300(the price for a bare frame), you can install subframe connectors, a martz four bar rear suspension, and upgrade the stock front suspension, and likely have some money left over. the basic unibody design, while a bit too flexible for racing, is a good base for performance modification. adding subframe connectors is not a big weight penalty for the added stiffness you get. but adding a full frame is going to be a big weight penalty for the advantages of a full frame car. a reasonable idea in theory, but in practice, no.
Bullitt
Packin' Heat
2,743
Houston, TX
Jul 2, 2006
  • Jul 2, 2006
that's some really really nice work there. looks like some fairly high quality circletrack parts.
i hardly think the intent of that setup is for a "street" car, but it's definetally flawed as a racecar too. i agree that the "bolt-in" installation is really flawed, but the basic concept is good. most of the true racecars (and basically all of the winning ones) i've seen are basically unibody cars with tube front and rear ends and a cage that ties them together. granted this is a little different from what is basically a stockcar chassis minus the roof/cage that is bolted to the bottom of a normal body, but it's the same basic idea.
J
  • JasonB66
  • Jul 23, 2026
  • Suspension
Suspension Jul 23, 2026
JasonB66
J
For Sale 3-owner 1987 Mustang GT, $18K obro, Lancaster CA
  • Bill Cool
  • Oct 6, 2024
2K
Fox Body Mustangs For Sale (1979-93) Oct 13, 2024
nickyb
SN Mustang Magnum T56 swap
  • revhead347
  • May 24, 2024
  • 1994 - 1995 Specific Tech
7K
1994 - 1995 Specific Tech Jun 28, 2026
GearHeadGuy
Took some pics, i do really own a mustang...
  • 2000xp8
  • Jun 20, 2023
  • 6 7 8
21K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 1, 2024
Mustang5L5
K
SOLD 1988 Ford Mustang GT, lots of upgrades, Maximum Motorsports Suspension PRICE DROP $6800
  • kuhl0040
  • Aug 18, 2021
4K
Fox Body Mustangs For Sale (1979-93) Sep 20, 2021
