full length SFC
full legth are usually weld on... in fact i haven't seen ant full length that are bolt in... btw if they were they would be just as good as the stock ones... crap :)
peace out man
attachment.php
here's a pic... sorry it's best i have... it's right before i took everything off
thanks tarch. can you kinda describe where the the SFC are welded to the frame of the car for me? im trying to convince my dad to let me buy them but he doesnt want 1's that weld in because they wont allow any movement and will just break. kinda how a bridge sways a little bit and if it was rigid it would snap.
JonJon said:
how much is it to get the sfcs with the jacking points or whatever?
hmm they usually all should have jacking points... you may be thinking an extreme subframe connector setup where there is another bar parallel to the subframe connector on each side which reinforces the jacking points
The full lengths I installed had you weld in a torque box reinforcement (welcome addition for drag racing as well) that gives a nice firm flush place to mount them in the rear near the lower control arm. The front end of them mounted flush against the front subframe and the difference was night and day. I'm sure you're aware what it's like driving with out them. The car twists going over bumps and it's kinda like your sitting atop a horse. With the subframes the car just drives. It's rigid, harder to break the tires loose (SOOO Friggin needed in that department), it accells straighter and speed bumps are no longer the PIA they used to be. I opted for the Steeda zinc coated full lenghts with cross braces and torque box reinforcments. Happy as can be with em.
