Funny - cold start
  • Thread starter Thread starter bhuff30
  • Start date Start date Jan 7, 2010
bhuff30
6,037
35
129
Olathe KS
Jan 7, 2010
  • Jan 7, 2010
The weather here in Kansas has been bitterly cold and snowy. We finally got a sunny day with mostly clear roads a few days ago. I decided to drive the msutang that morning. I turned the key and the engine cranked very very slowly: RRRrrrr..... RRrrr..... Rrrr and the engine fired. The funny part was, that with each turn of the crank, I could see the dash lights go dim, as the starter sucked the battery dry. Well, I guess it is time for a new battery before I get stuck somewhere.
mustanggt04fast
105
  • Jan 7, 2010
you may have a bad alternator as well ive done that a few times thinking it was the battery and then a week later it does the same thing doesnt hurt having the alternator checked
K
Kilgore Trout
Fried or Broiled ?
4,749
95
134
Jan 7, 2010
  • Jan 7, 2010
Could also be a corroded cable or just loose/dirty terminal connections.
bhuff30
6,037
35
129
Olathe KS
Jan 7, 2010
  • Jan 7, 2010
I've had the car for a bit more than 5 years and never changed the battery, plus the temps were around 0F then and it cranks normally when the weather is above freezing. Go figure.
patman0911
2,287
Tuscaloosa, AL
Jan 7, 2010
  • Jan 7, 2010
5 years old? Your battery is probably near the end. Extreme cold is good at finishing off a marginal battery.
bhuff30
6,037
35
129
Olathe KS
Jan 7, 2010
  • Jan 7, 2010
Actually, I have no idea about it's age, but it is at LEAST 5 years old.
92armyGT
24
Oregon
Jan 8, 2010
  • Jan 8, 2010
I am in AK right now, it is -5 outside. The cold kills batterys fast. If you have an old battery that has been sitting, the cold sucks the Cranking amps out fast. They need to be maintained by starting up one a week, or a trickle charger. Here, if you don't have a battery warmer or start your car every few hours, you are done, your car is not going to start and you will be stuck. I know it normaly doen't get that cold in Kansas, but because you don't run it in the winter, I would buy a trickle charger also, so you can keep a good battery maintained.
bhuff30
6,037
35
129
Olathe KS
Jan 10, 2010
  • Jan 10, 2010
I had the battery tested and it was marginal. Not completely bad, but obviously going out.
The old battery was from 04. Anyway, installed the new battery and cleaned the terminals and it starts VERY aggressivly now.
I
Icemanstang
149
Potstown,Pennsylvania
Jan 10, 2010
  • Jan 10, 2010
Definitley trade in your old battery and get a new one because
it could die on you completely and leave you stranded in the middle of nowhere.I change my battery regularly every three years no matter what!
patman0911
2,287
Tuscaloosa, AL
Jan 10, 2010
#10
  • Jan 10, 2010
  • #10
Mine only last about 3 years because of the heat down here. Luckily, my last one was under waranty - woo hoo!
stangGT97
1,299
Boston area, MA
Jan 11, 2010
#11
  • Jan 11, 2010
  • #11
I have an optima red top with 800+ CCA or something crazy like that! I have my stang in storage right now, with the battery disconnected. After a month of being exposed to sub-freezing temperatures and not being started, I hooked up the battery and the car started right up. Now I am glad I got rid of the cheapo Wal-Mart battery that came with the car!!
E
2007 GT Stalls when lights or a/c turned on
  • ejscarfo
  • Jun 22, 2026
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech Sep 26, 2026
manicmechanic007
T
2001 GT 4.6 V8 weak crank no start.
  • The-Bamboo-Farmer
  • Nov 12, 2025
1996 - 2004 SN95 Mustang -General/Talk- Nov 13, 2025
The-Bamboo-Farmer
T
F
1986 mustang no start
  • foxyjamss221
  • Oct 11, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 13, 2025
foxyjamss221
F
Hard to start when engine is cold
  • 86_Capri
  • Mar 11, 2026
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 21, 2026
CAMTWO1070
Engine Another no start after washing engine bay
  • bruno
  • Apr 26, 2026
Fox 5.0 Mustang Tech May 7, 2026
AeroCoupe
