fuse block
  • Thread starter Thread starter Cobain03
  • Start date Start date Jul 3, 2007
Cobain03
996
Lexington, Ky
Jul 3, 2007
  • Jul 3, 2007
what do you guys recomend for changing fuse block i want to change mine and update it and clean it up maybe add 2,,, 1 for hot all the time and 1 for acc got any ideas or pics
thanks
smitzer
100
Colorado Springs, CO
Jul 3, 2007
  • Jul 3, 2007
have not used one myself but I thought these were pretty cool:
http://www.jegs.com/webapp/wcs/stores/servlet/product_10001_10002_39984_-1
67GTFB
  • Jul 8, 2007
and Painless has a couple of models - at least one with both circuits you want ....
BullittStangV8
1,104
NJ
Jul 8, 2007
  • Jul 8, 2007
What circuits would you guys tap for the "ignition" hot circuit? Some of the kits get there pick up/turn on signal from an ignition hot. They mention using fuse taps and the such.
Rusty67
20+ Year Stangneter
Dec 3, 2002
3,749
37
109
LA, CA
Jul 9, 2007
  • Jul 9, 2007
Depends on how much wiring you are planning on doing. Are you going to rewire the hole car or do you just want to add some circuits ?
BullittStangV8
1,104
NJ
Jul 9, 2007
  • Jul 9, 2007
just add circuits. like 7 ignition hot circuits. The painless system just needs an ignition hot signal to turn on the circuits.
Rusty67
20+ Year Stangneter
Dec 3, 2002
3,749
37
109
LA, CA
Jul 9, 2007
  • Jul 9, 2007
It doesn't NEED one, thats just one way of seting it up. I think the relay controls the power for the fuse block. You could always bypass the relay to make it hot all the time.
66candy
17
The Netherlands
Jul 9, 2007
  • Jul 9, 2007
Just last week I replaced my rusted fuse block with a modern version:
Erwin, The Netherlands
smitzer
100
Jul 9, 2007
  • Jul 9, 2007
That fuse block looks all too familar! I am in the middle of the full painless install. All that wiring is spinning around in my head.
66forfun
260
Pittsburgh
Jul 9, 2007
#10
  • Jul 9, 2007
  • #10
i used an add on (4 slot 10a) block, it came as a kit.
88dragtop
198
Glastonbury,CT
Nov 24, 2007
#11
  • Nov 24, 2007
  • #11
Can someone post what each fuse is for in the stock fuse block? I have a schematic I got here but it doesn't clearly show the wiring through the fuse block. My problem is no courtesy/interior lights but the guage cluster and gauge lighting works, just no lights under dash and doors, it was working
geostang351
946
Danb., CT
Nov 25, 2007
#12
  • Nov 25, 2007
  • #12
I have a 68 and the fuse that controled my gauges lights was the small fuse in the middle of the fuse block. It is the only one in he middle surrounded by the other fuses. Notice in 66candy's picture the one I'm refering to.
SJB Parasitic Draw, Fuse 59&67
  • 2005 Mustang V6
  • Apr 30, 2026
2005 - 2014 S-197 Mustang -General/Talk- Sep 29, 2026
boatillo
speedmaster new 302 block?
  • rednotch
  • Aug 9, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 16, 2026
rednotch
G
Help! Radio, door chime fuse keeps blowing.
  • goofyfoot53
  • Sep 9, 2025
  • 2.3L (N/A & Turbo) Tech
2.3L (N/A & Turbo) Tech Sep 9, 2025
91AOD5.0LX
C
No Crank--have power(accessories)
  • chazmanaz
  • Oct 11, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 17, 2025
chazmanaz
C
Block questions
  • s_vargas54
  • Jan 25, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 8, 2026
Trogdor
