  • SN95 4.6L Mustang Tech
Fuse box question
  • Thread starter Thread starter shadow04GT
  • Start date Start date Jun 19, 2004
shadow04GT
22
Huntsville Alabama
Jun 19, 2004
  • Jun 19, 2004
04 Mustang Gt
Got a question about getting to the fuse box in the drivers compartment. I removed the two bolts on the panel under the steering wheel however it doesn't want to pop out. Am I missing some bolts to remove? Is there a certain direction I need to pull to get this panel off without snapping anything off?
Tks
N
n0v8or
604
Rhode Island
Jun 19, 2004
  • Jun 19, 2004
Why do you want to remove that panel? You can access the fuses with it in place.
There are 3 or 4 blind clips retaining the end of the panel closest to you. I usually wrap a big screwdriver with duct tape and pry gently at the seam between the panel and the dash to get it started. Pull the top edge of the panel in a direction perpendicular to the steering column.
There is a sheet metal cover directly behind the plastic one. It is retained by 2 more bolts.
M
1996 GT Speedometer electrical nightmare
  • moon96gt
  • Oct 7, 2026
SN95 4.6L Mustang Tech Oct 17, 2026
CAMTWO1070
A
SN95 Multifunction Madness! Need some big brain assistance from you folks
  • Awnaw
  • Oct 28, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 28, 2026
gkomo
P
Electrical 2001 GT Overcharging
  • PseudoGT
  • Dec 3, 2025
SN95 4.6L Mustang Tech Dec 13, 2025
N
Power door lock motor Question
  • NYFox
  • Mar 15, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 17, 2026
NYFox
N
D
Progress Thread Today in the shed........
  • Don7Up
  • May 5, 2026
  • 2 3
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Friday at 3:52 PM
AeroCoupe
