FYI: oil can purge through oil sensor!
denialdave
223
North of Seattle
Yesterday I drove my car to a friends in the rain. At his house we hopped in his truck. While driving down the rode we noticed an oil slick in the other lane and commented (after about 4 miles) how that guy was probably screwed!
When we came back we realized the slick was in his driveway and under my car (99 cobra). In that four miles I lost all but a quart of oil, luckily it was at 25mph and very cool outside.
I called the SVT service manager today and they said the oil sending units have a diaphragm that can give out and you "will quickly purge the engine of oil".
I never saw the engine light come on, and when I filled it up with oil and changed the sensor it fired up just fine--but I think I could have toasted the motor easily if I had been on the highway listening to the radio. By the time the red light would come on you'd be permanently gluing stuff together, or dropping parts out the bottom!
So the factory pressure sender suffered from a failure & proceeded to bleed out a large volume of oil? :shrug:
When you removed the faulty oil pressure sender, could you visually see any damage to it? :shrug:
I thought that the factory oil pressure gauge/sender was a joke anyways, seeing as how it is just an 8psi open/closed switch (certainly 8 psi is not enough pressure when you're driving moderately).
I think 20 - 25 psi is standard at idle. Just another reason to wire up an aftermarket oil pressure gauge since the factory one is junk.
My .02
