G-trac bar and Caster/camber plates?
tack_78
87
When I installed my tubular K-member, there was a k-member brace on the stock one. Myself and Cliff believe that this brace is only on verts. I want to put a g-trac brace on. The one that Steeda offers says except verts. Will this fit on my car now that I have a tubular k-member? Also, what caster/camber plates should I get? What is the difference between three and four bolt plates?
poolee said:
The brace you're talking about is only on convertibles. It prevented my engine from going in with a the big canton oil pan, so I took it off. Instead of the g-trac, I'm ordering a 4 bolt brace piece from Maximum Motorsports.
http://www.maximummotorsports.com/kbrace.asp
I can't use the four-point brace because I have BBK Longtubes. I already ordered the steeda G-trac. I just hope it fits. If not, I will return it.
