Garage Sale-Race Parts for Sale
RACE PARTS FOR SALE
1) Ford Racing Sportsman II 351W 9.5 Deck Block-.040 2-Bolt 3” Mains Rated to 800hp.
$ 850.00 List $1450.00 Pick-Up Only
2) DSS 2-Bolt Main Stud Girdle $ 225.00
3) Set SRP 408 12.5/1 Flat Top Pistons w/pins .030 $ 350.00
4) Set SRP Custom Edelbrock Victor Senior .040 Pistons w/pins List $1138.00 $ 850.00
5) Eagle 4340 H-Beam 6.250 Rods $350.00
6) Eagle 4340 Crank 4.000 .020 Mains .010 Rods $300.00-SOLD
7) Comp Cams Custom Grind .743 int & exh (email spec.) Dyno only 302,351
$ 225.00
8)Comp Cams Custom Grind .661 int. .668 exh. (email for spec) 302&351W
$ 200.00
9) 16-Comp solid roller lifters 302 & 351W $ 350.00
10) 16 Comp Cams Magnum 1.6 Roller Rockers $ 200.00
11) Pair AFR “Outlaw” Racing Heads-2.08 valves recessed
for .750 lift on flat top pistons w/1550 springs. 302 & 351W. Cost $2,150 w/machine & springs $ 1,450.00 12) Edelbrock Victor Jr. Intake 351W 9.5
$ 225.00
12) Edelbrock Victor Senior Intake– 351W 9.5 Gasket matched, ported
$ 275.00
13) MSD 351W (big cap) Bronze gear Billet Distributor fixed
advanced incl. kit to change to reg. advance +extra Cap and steel gear.
$ 190.00
14)2-sets QA-1 & Comp. Engineering Coil Over Adapters to use coil over's $ 75.00
16) Pair Strange Pro Race Hardened 33 Spline Axles-C-Clip Eliminators, 5/8" studs 8,8 86-93 mustang $ 475.00
15)Kooks STAINLESS 1 7/8” Headers w/3” Magnaflow 40 Mufflers w/turn downs $ 875.00
16) QA-1 14” coil over springs. Assorted weights from 110lb-175lb $ 40.00pr
17) Pair Fabricated Aluminum Valve covers-dent in rear (can’t see when on) $ 125.00
18) JW Reverse Trans brake List $ 385.00 $ 285.00
1050 CFM 4150 Race Demon w/removable sleeves down to 880cfm $ 750.00
19) 770 CFM throttle plate and sleeves for 4150 Race Demon $ 175.00
20)1095 CFM 4500 King Demon w/ removable sleeves 1195 CFM $ 850.00
21)Holley 4150 750CFM Double Pumper w fuel connectors $ 250.00
22)HVM 4150 2” super Sucker carb spacer $ 75.00
MORE ITEMS TO COME...PM ME FOR PICTURES!
NOTICE: I AM NOT ON THIS THREAD AS MUCH SO PM ME IF YOU WANT MORE INFO OR PICTURES.
THANKS
….ALL ITEMS ARE + SHIPPING
