My wife ran my car out of gas today. Its the second time Its happened.
I have been filling up around every 130 miles just to be safe, I computed the gas mileage at about 17mpg. Which from what I read is on the low side of average. But today It ran out at 143 miles.
I am guessing the tank capacity is 16 gallons. Which should around 270 miles per tank. Where do I start with trying to figure this out? I really do not know much about what has, or has not been done to the engine. both maintenance or performance. It does not sound like the cam has been changed. it has the stock intake on.
Here is what I do know about the car.
89 GT Vert, 107,xxx miles.
alternator is charging at 11.8 volts at idle.
smells like it is running rich.
pings intermittantly under load.
The car will die if I down shift through first and come to a stop.
I pulled 2 codes using a "brain scanner" code reader that my buddy loaned me. It was for 34, and 91. I did a search and came up with EGR and fuel pump.
I have not been able to check the timing to see if its been advanced. It idles smoothly and starts on the first crank.
My first thought was that the fuel pumps gasket had failed, but then I realized the fuel pump was not attached to the motor
Where should I look first? I would assume the low output of the alt is causing the dying problem. It is hard to replicate, it happens about 1 out of ten times when coming to a stop.
My exhuast is not blowing smoke, But I can smell gas in it when I have the top down. It smells a lawn mower.
sorry if my post seems a bit out of order. I have both my babies and my wife hollering at me.
