Mean03V6
doc4444 said:One of the things that might effect your mileage is the type/quality of gas you use. Always try to stay with the same brand, Mobil is good, Chevron too. I would stay away from Exxon and Amoco. The idea is if you keep changing your type of gas your car is not able to adjust to the chemicals in one type and make optimal use of them. Also keep in mind that Chevron has Techron and Texaco has Clean System 3 these also help out with keeping your fuel system, including injectors clean, hence better gas mileage. Yes you pay a little more for this gas but the benefit to your engine is worth it. Especially one that can be as temperamental as ours.
Hope this helps.
Doc![]()
Anything special about Shell gas? That's what I tend to use...been on it for about 2 months now after switching from Chevron, which I might be going back to permanently since Shell seems to be the most expensive gas.
