gas mileage questions
  • Thread starter Thread starter usmc88gt
  • Start date Start date Oct 5, 2004
U
usmc88gt
  • Oct 5, 2004
I know there are plenty of threads about this but I need to ask some questions. I have a 88 gt with a 306,cobra upper and lower, e303 cam, 1.6 rr's, underdrive pulleys, gt40 aluminum heads, 24# injectors, be-cool radiator and other small things i dont think will matter. the previous owner removed the a\c and the heater components. If the egr spacer is missing can this hurt my gas mileage? I just did a tune up. As soon as I get a chance I'll go to the dyno and get my a/f ratio. this is my daily driver for now so what would be the best timing and fuel pressure to run for the best gas mileage possible.
thanks guys.
D
Daggar
3,902
  • Oct 5, 2004
Best gas mileage??? That's a first. Since you're going to the dyno anyway.... tune it to the factory 14.7 AFR across the powerband then maybe have them juice it for maximize horse power at WOT. So long as you keep your foot out of it then your gas mileage should be about as good as it's gonna get. You still running SD or MAF? If you're still running SD then getting a chip programmed to deal with that cam will make a world of difference in your fuel mileage. I imagine that with the 24 lb injectors, the E cam, and the stock EEC program that you're probably running rich as hell right now (stock regulator + decreased vac = too much fuel pressure + larger larger injectors = too much fuel (assuming a stock EEC program and fuel tables)). Just getting a custom chip should make a big difference. My suggestion: Tune it for power and let the fuel mileage take care of itself. Another option is to get multiprogram chip with two programs. One for power and a flip of a switch for fuel economy.
U
usmc88gt
  • Oct 5, 2004
thanks for the reply. sorry i forgot to mention i have mass air and msd 6al and a after market fpr and a dyna-mod for the distributor. If I replaced the egr plate do you think that would help any. Also my coolant temp hardly ever goes over the L. i have a black magic fan, should i adjust it to let the engine get to a higher operating temperature?
D
Daggar
3,902
  • Oct 5, 2004
I don't think the EGr palte will make much of a difference in your fuel mileage and if your air pump it gone it's pretty mucha moot point anyway. Check your T-stat... if you've got a 160 in you should consider ditching it for a 180. The dyno should tell you the rest.
U
usmc88gt
  • Oct 6, 2004
Thanks appreciate your time
smac61
294
SC
Oct 6, 2004
  • Oct 6, 2004
FWIW...the Cobra intake does not use an EGR spacer. It's 'built in' for lack of a better term.
  • Gulftown980x
  • Jul 29, 2026
  • SN95 4.6L Mustang Tech
squeak93
Requesting Guidance for 306 motor swap - Fuel? - SD? MAF?
  • So_Flo
  • Jul 26, 2025
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jan 4, 2026
Mcmahst
  • 68_Disgustang
  • Feb 22, 2026
1965 - 1973 Classic Mustangs -General/Talk- Jun 20, 2026
gray owl
G
Progress Thread Giving an abandoned 88 GT project a new chance at life
  • jaketractor
  • Jan 9, 2025
2K
Fox 5.0 Mustang Tech Jul 20, 2025
Engine Raising compression on a relatively stock 302
  • keel
  • Jul 9, 2023
9K
Fox 5.0 Mustang Tech Jul 20, 2023
keel
