87'GTstang
- Feb 16, 2004
- 1,025
- 0
- 0
Basically new spark plugs, new Distributor cap, new wires, oil and trans fluids changed, new oil, air, and trans filter (if aplicable) replaced. tires rotated, air pressures adjusted, various axles, ball joints, bearings, linkages, ect. greased, radiator flush, oxygen sensors replaced, fuel injectors cleaned, belts/chains replaced if necessary, differential lubricant changed, MAF sensor wires cleaned, and so on just to name most of the key things.Highway High said:What does a full tune up consist of? Im getting around 12 mpg every fill upGranted, I don't keep my foot out of it, but I really dont drive it too aggressively now, just the occassional romp. I drive a lot and freaking filling up like every other day is starting to get expensive.
Logan
Ummm.....BOTH
