I have a 94 GT with a aode trans, I just put a Cobra intake on it with a cold air kit and and H pipe with no cats. I also replaced the Fuel pump with a New 155lph, pushing the gas through a oem fuel regulator. Now when I put that upper intake on I had to redrill the egr hole so that it would fit but also in the process I broke that metal tube that connects the egr to the top of the header, I'm getting a CEL now and run the codes and was a egr insufficient flow code. I have run a 1/4 mile pulled over and the plugs are not wet but yet If i drive just 25 miles it will use a 1/4 tank of gas i know that I own a soon to be quick car and am not looking for 50 miles to the gallon but dang i would like to know where the gas is going i do the speed limit any help or idea's would be helpful. thank you
