1 19mustang65 New Member Apr 25, 2004 201 0 0 Phoenix AZ Oct 2, 2004 #1 Oct 2, 2004 #1 i know this must sound like a stupid question. but what size is a standard gas tank on a 65 289 coupe?
MustangPaul Founding Member Jun 20, 2002 514 0 0 South East Louisiana Oct 2, 2004 #5 Oct 2, 2004 #5 If you want a couple more gallons, you can run some of the bigger tanks, just make sure to swap the sender, too.
rbohm Founding Member Apr 12, 2002 6,698 550 204 tucson,az Oct 2, 2004 #6 Oct 2, 2004 #6 i plan on using a 70 mustang tank, it is 22 gallons. it is bolt in swap you do have to use the 70 sending unit.
R Ronstang New Member Apr 4, 2004 1,294 0 0 Houston Texas Oct 2, 2004 #7 Oct 2, 2004 #7 rbohm said: i plan on using a 70 mustang tank, it is 22 gallons. it is bolt in swap you do have to use the 70 sending unit. Click to expand... That is what is in my 66 Fastback. The extra size gave me more room for the EFI intank pump also.
