  • 2015 - 2023 (S550) Mustang -General/Talk
Gas?
  • Thread starter Thread starter ccoff864
  • Start date Start date Aug 8, 2015
1 of 2 Next Last
C
ccoff864
27
Lexington SC
Aug 8, 2015
  • Aug 8, 2015
What gas is everyone running and why? What are any benefits or reasons that you are running what you are? TIA
OracleHCR
152
23
39
Crestview, Fl
Aug 9, 2015
  • Aug 9, 2015
93 octane and I only use top-tier gasoline. 93 octane because why wouldn't you? The Coyote produces more hp with higher octane. I only use top-tier gas because I want the fuel I put in my vehicle to actually be beneficial and not leave deposits and hamper engine performance. I generally use Shell but will use BP or Chevron also.
echo7
706
41
59
FL
Aug 9, 2015
  • Aug 9, 2015
I like Sunoco 87 octane. I drive it 40 miles round trip to work, so I prefer to save a little. Never been in a position where I wish I had filled it with 93 either. Although, when I do the math, it's probably only about $20-$25/month savings. But, when you buy a Mustang that's $10k more expensive than you bring home in a year, you gotta be cheap.
Reactions: Still Bill and ccoff864
usaf_branham
927
134
84
Boston
Aug 10, 2015
  • Aug 10, 2015
87 because I can... 93 made next to no difference in fuel Econ or perf.
Sent from my iPhone using Tapatalk
84Ttop
5 Year Member
Jul 2, 2009
5,222
3,254
204
South Jersey
Aug 10, 2015
  • Aug 10, 2015
93 only for me... because it's supercharged and detonation is a bad momma, lol
Reactions: ccoff864
NJBob
102
17
38
NJ
Aug 10, 2015
  • Aug 10, 2015
Right Now I'm trying Shell 93 V-nitro to see how the car runs. I just did my first tank and will do 2 more. Then I'll Try BP for 3 tanks and then Exon / Mobil.
Right now the only thing I know for sure is the weather effects the performance more than anything. Hot over 90 humid days, sucks the life out of the car.
Mattstang04
1,152
144
104
St. Louis, MO
Aug 10, 2015
  • Aug 10, 2015
More octane allows for the engine to run more aggressive timing and that means more power. I use 93 octane, usually Phillips 66, BP, or Shell.
Still Bill
92
17
28
Washington State.
Aug 12, 2015
  • Aug 12, 2015
Shell or Chevron 92. That's the best available to me here. I just turned 10k on the odometer and no troubles so far. Probably would not be driving everyday had I bought the GT. I would have felt bad about putting so many miles on it. I don't baby this thing either. I been having fun throwing down with some of the local tuner boys and kick g their asses. I try to tell them it ain't always just about power. Gearing and just plain getting the power to the ground at the appropriate time makes a big difference.
Stan McKinney
78
Aug 12, 2015
  • Aug 12, 2015
Ford recommends 87
Detector
62
10
29
Aug 13, 2015
#10
  • Aug 13, 2015
  • #10
No 93 here or anywhere close so it's 87
coupestang2
108
132
53
Cornelius NC
Aug 13, 2015
#11
  • Aug 13, 2015
  • #11
93 ethanol free for my blown 93 coupe
dhcolesj
207
Dickson, TN
Aug 13, 2015
#12
  • Aug 13, 2015
  • #12
I'm running 92 or 93 depending on what's available here. The Shell station local decided that we must be rich, or that they wanted to be and jacked up the premium price to crazy, so I've had to seek other sources.
OracleHCR
152
23
39
Crestview, Fl
Aug 13, 2015
#13
  • Aug 13, 2015
  • #13
Stan McKinney said:
Ford recommends 87
They actually recommend a minimum octane rating of 87 for the GT. They recommend 87 for the V6 and the Ecoboost. You lose HP using 87 octane (35 HP in the Ecoboost). The 435 hp rating in the GT came with 91 octane. You will lose 1% of the HP rating using 87 octane.
Stan McKinney
78
Aug 13, 2015
#14
  • Aug 13, 2015
  • #14
A 1 percent loss for a car rated at 310 horsepower would be 3.1 horsepower. A 35 hp loss would be about a 31 percent loss.
OracleHCR
152
23
39
Crestview, Fl
Aug 13, 2015
#15
  • Aug 13, 2015
  • #15
The GT loses 1%. The Ecoboost suffers a 31% loss using 87 octane over premium.
Stan McKinney
78
Aug 13, 2015
#16
  • Aug 13, 2015
  • #16
My math is wrong. Was good at math in my younger days. That is about an 11 percent loss. 35 percent would be more than 100 hp
OracleHCR
152
23
39
Crestview, Fl
Aug 14, 2015
#17
  • Aug 14, 2015
  • #17
My math was wrong too since I didn't even bat an eye at your numbers. It is a pretty big loss in power no matter which way you do the math. If you are getting the Ecoboost for performance then you should use premium.
If you are getting one for gas mileage and economics, use 87. As you stated earlier, Ford recommends 87 in the Eco and V6.
Stan McKinney
78
Aug 14, 2015
#18
  • Aug 14, 2015
  • #18
I use 87, get 34 MPG and more on the highway and have plenty of power. I may try higher octane just to see if I can feel the difference.
Admin Dude
Jan 4, 1985
43,349
21,546
234
Box behind Walmart
Aug 14, 2015
#19
  • Aug 14, 2015
  • #19
You will probably not 'feel' any difference at all. It takes a roughly, 30 HP difference for the Seat Of The Pants dyno to kick in. Where the difference will show is in responsiveness, and a 3-ish HP difference over the entire range of RPM.
On a race track, that difference will become apparent pretty quickly. Between your house and the door of the Safeway? Probably not too much unless you're the type that's door to door with someone every time a light turns green.
On a side note: I would have no issues whatsoever running 10% Ethanol. It's cheaper, comes by it's octane rating honestly, and late models are designed to use it. Fuel system parts were designed to use it and fuel injectors are sized accordingly for it. The only real difference that you will ever notice is that you get more distance out a full tank of straight gas vs. 10%.
My old boosted pushrod? Yes, I prefer straight gas when I can find it. You all's cars? Hell, I wouldn't give 10% a moment's thought. It's nice to have computers able to adapt to fuel potential.
Bullitt347
I have been doing it wrong this whole time
3,998
2,984
194
Middle of Maine
Aug 14, 2015
#20
  • Aug 14, 2015
  • #20
I run ethanol free gas, but it is more expensive per gallon compared to the "top tier" stations. I did notice a improvement in fuel economy and overall throttle response as well as idle quality. The improved fuel economy of 1-3 mpg does not offset the added cost per gallon though. So it is more expensive to run the ethanol free stuff, at least for me. I buy it anyway because of the improved way the engine runs and responds. (or at least perception of such) and around here 92 octane is as good as it gets, no 93 octane available.
1 of 2 Next Last
G
Octane on the 5.0 Coyote
  • gray owl
  • May 17, 2026
2015 - 2023 (S550) Mustang -General/Talk May 27, 2026
Bullitt347
H
Hesitation & sputtering
  • healy1963
  • Apr 16, 2026
2005 - 2014 S-197 Mustang -General/Talk- Apr 16, 2026
healy1963
H
L
1997 V6 Starting issue
  • leanzik04
  • Mar 20, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Mar 20, 2026
D
After Market fuel rails with Stock fuel lines
  • dropteeth
  • May 1, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 2, 2026
2000xp8
D
Exhaust set up
  • dropteeth
  • Sep 20, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 24, 2025
AeroCoupe
