gaskets and juice
  • Thread starter Thread starter tannerc91gt
  • Start date Start date Dec 16, 2009
tannerc91gt
This last 25% is foreign territory at this point
2,967
234
Indiana
Dec 16, 2009
  • Dec 16, 2009
alright, so ive ordered parts to put on the car next week and i picked up a TFS track heat intake today. Been putting together another summit racing order for gaskets and a few things and hit a delima.
The ports on the lower intake are obviously larger than the ports on the stock E7s, therefore air will hit that exposed edge of the heads. my question is, do i go with the felpro 1250 gaskets that match the LOWER INTAKE ports but leave that extra edge bare or do i get stock lower/head gaskets that will cover the exposed edge?
i also ask this because im running a wet nitrous kit. Im worried that those edges will allow fuel to puddle in the intake, and well we all know how that ends up. should i switch to a dry kit to avoid that all together? or will i be alright? I dont want fuel to ruin the gaskets either.
sorry if these questions are stupid but this is my first build of my own and i figure ill have plenty along the way
capri debris
289
PA
Dec 16, 2009
  • Dec 16, 2009
There's really no reason to have a bigger intake on than the heads can handle. They call it "tuned port" injection because the tuning of the intake ports is important because the air speed through the ports is critical. With a bigger intake than the heads can flow, it will cause the air velocity of each port to be slower... not good. I suggest you put the stock intake back on until you have heads that can support the TF intake.
stykthyn
5,232
2,652
223
gainesville
Dec 17, 2009
  • Dec 17, 2009
the track heat will kill any low end you have on a stock setup. its power will come on later and by that time your heads are going to be struggling breathe...
rbonella
409
@ home
Dec 17, 2009
  • Dec 17, 2009
I agree, put the intake aside for the time being. With e7's, your cam and intake are perfectly matched. I put a gt40 tubular w/65 tb on a stock shortblock back in the day and it hurt OVERALL performance. When I replaced the heads with gt40's, everything woke up quite a bit
90lxcoupe
20+ Year Stangneter
Oct 7, 2003
3,596
350
134
Dec 17, 2009
  • Dec 17, 2009
I agree that your gonna loose low end with that intake on the motor, but you will never notice it on the spray, and alsoi wouldnt go switching to a dry kit, i dont think you are gonna have a fuel problem. Just use whatever gaskets are for the intake and you will be fine. It wont be ideal, but sometimes you just gotta work with what you have
tannerc91gt
2,967
234
Indiana
Dec 17, 2009
  • Dec 17, 2009
i figured a slight decrease in low end would be made up with gears and spray. maybe im wrong, but i know there are plenty of people running stock heads with an intake, as the stock intake flows so terribly.
90lxcoupe
20+ Year Stangneter
Oct 7, 2003
3,596
350
134
Dec 17, 2009
  • Dec 17, 2009
If you hate it you can always put the stock intake back on...
Engine 95 GT and 95 Cobra sensors and TB gasket
  • Sonic
  • Dec 21, 2025
  • 1994 - 1995 Specific Tech
1994 - 1995 Specific Tech Dec 23, 2025
WhiteCobra95
Engine Felpro 9333 pt1 (with 8psi boost)
  • JD1964
  • Jan 14, 2026
Fox 5.0 Mustang Tech Feb 1, 2026
Qtrhrse23
A
Discussion on mild budget build/ top end
  • Acesario
  • Feb 21, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 23, 2026
General karthief
D
Fuel pump upgrade
  • dkrupp79
  • Jul 7, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 10, 2025
Scrapla347
water pump installation questions
  • B0udreaux
  • Feb 5, 2026
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 28, 2026
General karthief
