  • SN95 4.6L Mustang Tech
gaskets for mid pipe install
  • Thread starter Thread starter 87 blown stang
  • Start date Start date Dec 29, 2004
87 blown stang
139
pa
Dec 29, 2004
  • Dec 29, 2004
i seen in another thread that there is a gasket between the manifolds and midpipe? i bought my prochamber used. what do i need to get and where do i get them? also they said that one of them is metal, my car has like 3000 mi on it, would the stock one be ok, or is there one stock? also they were talking about getting new studs? i just want to cover all bases before i rip the stock off.
ShadowGT
202
Western Kentucky
Dec 29, 2004
  • Dec 29, 2004
There is one metal gasket on the passenger side (if I remember correctly) manifold where it connects to the mid pipe. I put my X pipe on when my car only had about 10k, but I went ahead and replaced the gasket anyway. The original probably would have been fine, but they are only about $7 from Ford, so I thought I'd play it safe.
You should be able to get them from any Ford parts dept.
ooraceredgt
204
  • Dec 29, 2004
yea get a new gasket from ford and save alot of time and trouble
mity2
I like Pro3 and all I got was this crappy CT.
Jul 24, 2003
2,872
StateCollege PA
Dec 29, 2004
  • Dec 29, 2004
usually, depending on the miles on the car, the composit gasket on passenger side can be reused tho. i suggest that you change them, but in the pintch, you can reuse them
TweekedGT
1,274
Alberta
Dec 30, 2004
  • Dec 30, 2004
I reused mine when I put my prochamber on. Still works like a charm.
COBRA90GT
Mustang Master
Sep 22, 2001
6,654
HOCKEYTOWN ® , MI
Dec 30, 2004
  • Dec 30, 2004
ShadowGT said:
...The original probably would have been fine, but they are only about $7 from Ford, so I thought I'd play it safe.
You should be able to get them from any Ford parts dept...
Agreed, that gasket is cheap so it's a good idea to replace it with a new one.
But you can re-use the old one if it's in good shape if you are really on a tight budget...
J
Exhaust manifold to Y-pipe nut & stud dimensions?
  • joeybuddy96
  • Jul 7, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Jul 9, 2026
joeybuddy96
J
R
bbk shorty header to mid pipe gasket
  • randyyy
  • Sep 29, 2025
1996 - 2004 SN95 Mustang -General/Talk- Sep 29, 2025
randyyy
R
D
Running both lean and rich with O2 heat codes
  • Danceswithfire5
  • Aug 30, 2026
SN95 V6 Mustang Tech Sep 5, 2026
apple99Mustangdude
A
Engine Motor swap from a 2003 Explorer
  • 1996mustang new
  • Oct 9, 2025
SN95 4.6L Mustang Tech Oct 16, 2025
squeak93
water pump installation questions
  • B0udreaux
  • Feb 5, 2026
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 28, 2026
General karthief
