Gauge suggestions??
  • Thread starter Thread starter The Shape
  • Start date Start date Feb 2, 2006
1 of 2 Next Last
The Shape
2,224
East ARKANSAS Delta
Feb 2, 2006
  • Feb 2, 2006
I just ordered the radio panel that holds three 2 1/16th gauges for my GT. I know for sure I am going to put in a mechanical oil psi and mechanical temp gauge. Any suggestions on another usefull gauge for the other spot?? I was thinking the of putting in a voltage gauge, but I don't run any stereo equipment or electric fans, so if there is a gauge I could get more use out of I would go that way.
srothfuss
Last night I stabbed the same guy 7 times in a row
Oct 17, 2004
1,796
Woodward Ave.
Feb 2, 2006
  • Feb 2, 2006
I did in this order :
Water Temp
Oil PSI
Oil Temp
88Stangboy
Banned
Dec 12, 2005
342
Greenville, SC
Feb 2, 2006
  • Feb 2, 2006
Water Temp
Oil PSI
Oil Temp
Agree'd. Then mount a Fuel PSI out on your hood. Those things come in handy.
HISSIN50
34
129
Feb 2, 2006
  • Feb 2, 2006
One other option is a vac gauge for your SD car. I have one in the 88 since vac signal is so important.
The voltmeter in my fox is not as inaccurate as the other gauges so I see your line of thinking James.
Good luck bud.
mbsprinks281
58
Lockport, IL
Feb 2, 2006
  • Feb 2, 2006
I did Water temp, oil temp, trans temp(its auto). I have a small electric fan on my trans cooler so the trans temp gauge comes in handy if things get a little warm......
Zero_chance
1,244
Maricopa, AZ
Feb 2, 2006
  • Feb 2, 2006
Do you plan on running boost or laughing gas? If not, I personally would run voltage. Why replace the other two stock gauges with more accurate ones and not do the third? Thats just my way of thinking. Chances are the voltage gauge is also innacurate and an upgrade could pinpoint an over/under charging issue in the future.
The Shape
2,224
East ARKANSAS Delta
Feb 2, 2006
  • Feb 2, 2006
Nah my car will never see boost or nitrous. I k now the voltage gauge is important. Heck my stocker registers in the red unless I smack the gauge so I should probably get one, but I was kinda leaning twoards a vaccum gauge like Hisssin suggested since I am still SD.
HISSIN50
34
129
Feb 2, 2006
  • Feb 2, 2006
We can think of a lot of cool gauges - how about a trans temp gauge? It kinda sounds like a voltmeter would be cool though. Uh oh, you need to find a place for more gauges.
stangjunkie
381
  • Feb 2, 2006
ill give my usual... i stoped goin with mechanical guages because i as drivin my old mans car a while back and the oil temp line broke and my crotch then became the temp guage and the oil as hot.... just my 2 cents
90NotchBack
306
Loxahatchee/Pembroke Pines, FL
Feb 2, 2006
#10
  • Feb 2, 2006
  • #10
I run a tach, oil pressure, oil temp, trans temp, volts, fuel pressure. I also have a Nitrous pressure gauge but that in the trunk.
The Shape
2,224
East ARKANSAS Delta
Feb 2, 2006
#11
  • Feb 2, 2006
  • #11
That bothers me too, but I really want the full sweep of a mechanical gauge.
srothfuss
Oct 17, 2004
1,796
Woodward Ave.
Feb 2, 2006
#12
  • Feb 2, 2006
  • #12
Forgot to post the link to my install earlier. Although, I used electrical gauges, you can still see lots and lots of pictures in the tread.
http://forums.stangnet.com/showthread.php?t=602481&highlight=Gauges
F
fiveohGT
353
Fairfax Virginia
Feb 2, 2006
#13
  • Feb 2, 2006
  • #13
Are mech. gauges more accurate then eletrical?
HISSIN50
34
129
Feb 2, 2006
#14
  • Feb 2, 2006
  • #14
Not in this day and age. I am like James in that I prefer mech gauges just for the full sweep as well (and you dont get that twitchyness that can come with elec gauges). Another gripe I have is that the needle width on an elec temp gauge can be worth a fair number of degrees, and any slight miscalibration can really affect the reading. With that said, I run a mix of gauges (mech and elec) in each car.
So said simply, go with you want - both will be accurate.
The Shape
2,224
East ARKANSAS Delta
Feb 3, 2006
#15
  • Feb 3, 2006
  • #15
Yeah that old thread is where I got the idea at. :SNSign:
04sleeper
2,674
14
89
Dallas, TX
Feb 3, 2006
#16
  • Feb 3, 2006
  • #16
I would go with Mechanical oil and water as well. I have never had an issue with either and I have been running them for the last 15 years or better.
I like the idea of the water gauge not needing any power for it to work. You can look at it at any time and get exactly what it is reading. (Kind of like sticking a thermometer in the intake.)
I also like the full sweep as well.
Also, as far as the oil gauge goes, I always use the $9 copper tubing kit and it has worked well for me. Some get a little chatter in the line but there are ways to quiet it.
The Shape
2,224
East ARKANSAS Delta
Feb 3, 2006
#17
  • Feb 3, 2006
  • #17
Yeah not having the gauges rely on the cars electrical system is what made me want mechanical. I had oil press. and water temp. electric gauges on my A-pilliar before and didn't really like them mounted there. Plus as Hissin said just the width of the needle was 10-15 psi so they are harder to read. And if the electrical system in the car isn't in top shape it can skew the reading of the gauges. I like that the phantom gauge I plan to use on this install just reads in 2 digit incriments for the oil press. so you can easily tell EXACTLY what the pressure is.
04sleeper
2,674
14
89
Dallas, TX
Feb 3, 2006
#18
  • Feb 3, 2006
  • #18
Sounds like a good plan.
See, a little research doesn't hurt....
Good luck with the install. Let us know how it goes.
Sicarius428
2,085
Feb 3, 2006
#19
  • Feb 3, 2006
  • #19
A good water temp gauge is really handy.
Kevin
The Shape
2,224
East ARKANSAS Delta
Feb 3, 2006
#20
  • Feb 3, 2006
  • #20
Thanks, now I just need to pick out a good CD player to install at the same time. Almost hate to see my factory stereo go. Where am I gonna play my cassette tapes at now???????
1 of 2 Next Last
C
Electrical Fuel Gauge...Help! What did I do or Didn't Do?
  • ChickenDeluxe
  • Sep 3, 2026
Fox 5.0 Mustang Tech Sep 3, 2026
ChickenDeluxe
C
M
1996 GT Speedometer electrical nightmare
  • moon96gt
  • Oct 7, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Oct 17, 2026
CAMTWO1070
Engine Themostat
  • Mindseye007
  • Jan 30, 2026
Fox 5.0 Mustang Tech Feb 1, 2026
86HO5.0
G
1991 GT 5.0 running hot
  • gvanginkel403
  • Jul 1, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 2, 2026
General karthief
T
Progress Thread 2002 Mustang 3.8L CV
  • TheIncompetentMechanic
  • May 26, 2026
1996 - 2004 SN95 Mustang -General/Talk- Jun 1, 2026
T
