Where did you guys run the hoses for center a/c console 2 5/8 gauges. I pulled the console out and expected to see a straight shot over to the steering column, but not. Can anyone help me out.
i just did mine yesterday.wata a pain. what i did was drill a little hole in the the duct as far back in the bottom left as possible.it makes it easier if you remove the panels from under the steering wheel. i also drilled a hole in the fire wall so i could run the line for the oil gauge and keep the line out of eye sight.as for the wire for the electric water temp ira it through the big hole by the master cylinder.if you take your time and do it carefully you will be way happier with the results!!!!
good luck phil
I drilled a hole in the firewall to run my copper oil press line, and the nylon vacuum line. I then used a big grommet and black silicone to seal it. The hole is at about the heigth level of the drivers valve cover, more or less.
